Dropped the bike
Discussion in 'XJ Technical Chat' started by autosdafe, Jun 26, 2011.
  1. autosdafe
    autosdafe Member
    Lorain OH
    So I dropped my bike last night and broke a turn signal. Today when I got to work I discovered gas in my oil. Apparently when I dropped it the carbs emptied thier gas into the air box and it poured down the case vent hose and in to the oil. At leats thats how it seems. So I dropped the oil and am going to replace. So should I worry? I put about 40 miles on the bike with gas in the oil.
  2. mirco
    mirco Member
    LaGrange Ohio
    Guys have ridden a lot longer than that with gas in their oil with no ill effects. No sense worrying about it. Change your oil and ride your motorcycle.
  3. TIMEtoRIDE
    Somebody reported 3 QUARTS in their oil, making it a 50/50 mix, and their motor didnt get ruined. If you picked the bike up within a minute, the most you would have would be about half a quart of "contaminant".
  4. autosdafe
    autosdafe Member
    Lorain OH
    sweet about what I figured. Better safe than sorry though. I figured all it did was dilute the oil.
  5. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    What the heck did you drop if for Jason? You just got it running! Are you trying to hurt yourself? That asphalt can hurt buddy....keep the rubber side down and it won't cost you parts or skin.
    Glad you and the bike are relatively ok.
    jeff
  6. autosdafe
    autosdafe Member
    Lorain OH
    I forgot to put the kickstand down before getting off. Believe me I am pissed at myself for doing it. But little damage and lesson learned.
  7. Robert
    Some consolance Auto, it is a very common lesson.
    Ride safe bro.
  8. TIMEtoRIDE
    Hey - I have a Maxim 750 style turn signal (same thing??)
    And I ship almost as quick as Chacal :eek:
  9. chacal
    No..... :(
    Well, let me clarify: the 1982 XJ750 Maxim uses the rectangular signals, and they are not the same. The 1983 XJ750 Maxim uses the same round turn signals as teh 550 Maxim models.
  10. Orange-n-Black
    Memphis Area
    Are you going back with originals, or are you going to take the aftermarket dress up plunge? Glad your ok.
  11. autosdafe
    autosdafe Member
    Lorain OH
    I'm going to go with nothing for now. Not a big deal looks better with out them
  12. JeffK
    I super-glued my signal on one of my other bikes after I hopped off and got 15' away, turned back to go back and set it in gear and watched it roll off the sidestand ....heartbreaking event.....anyway, that signal was glued with SuperJet Medium and that was four years and 16,000 miles ago.....still has the original bulb too. It was in 20 pieces but I reassembled like a jigsaw puzzle and it's still good to go...
    jeff
  13. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    Jason if your carbs still dump gas into your oil, you could have a stuck float..
    It happens when your carbs get in strange positions sometimes.
    You might be able to free it up by tapping on your float bowls.... be xtra careful though as you dont want to break anything.
  14. autosdafe
    autosdafe Member
    Lorain OH
    The carbs don't dump gas when held horizontal to the ground. They pour out when they get to 90 degrees to the ground LOL It doesn't appear to have any stuck floats.
  15. Hvnbnd
    St. Johns, Arizona
    Next question, does your oil level increase when parked for over night?
    That would indicate that a float is leaking by (needle and seat)
    None the less, having had gas in the crankcase is not good but if the problem is fixed and the oil and filter is fresh and getting any more gas in the oil......... What in the heck are you waiting for!!???
    Better get riding!!
  16. autosdafe
    autosdafe Member
    Lorain OH
    Rode today and it rode great!!!
  17. Hvnbnd
    St. Johns, Arizona
    EXCELLENT!!!
    Just keep the dirty side down now.
