Shim pool
Discussion in 'XJ Technical Chat' started by Harvey1, Jun 18, 2011.
  1. Harvey1
    Harvey1 New Member
    I was reading in an archive from 2005 that there was at that time a "Shim Pool" going on where a person could get the shims they need to adjust their valves ans send back the shims they no longer need. Is this still going on? I found a site where I could get shims but I can't remember which site it was.
  2. hogfiddles
    Yes, contact Brad Bowen for the shim pool, I also have a shim pool, and Len Chacal at info@xj4ever.com (or click on his logo at the top right of every page) sells new ones.
    Regarding mine, what size shim do you need, and what sizes do you want to swap? I'll see what I have/need.
    Dave Fox
  3. Harvey1
    Harvey1 New Member
    Thanks for the info! I haven't yet check my valve clearances, I'll try to get it done tomorrow and then I'll let you know.
  4. HirsuitHeathen
    HirsuitHeathen Member
    South Jersey
    Not to swoop in on your post here, but I was directed to find a "shim pool" I have 2 that I need to swap out for 2 smaller size shims. I have Y280 and a Y285. I need a Y270 and another Y275. If they are spoken for by Harvey1 could you direct me to someone who might be of some assistance? Thanks.
  5. RobDrech
    RobDrech Member
    Middletown, CT
    What a great idea!
  6. iwingameover
    iwingameover Active Member
    I'll look in the box and see what I have when I get to the shop tomorrow.
  7. HirsuitHeathen
    South Jersey
    Thanks man, you rock!
  8. iwingameover
    Well I have one 275, and everything else is bigger. If you want the 275 PM me an address I'll drop it in the mail for you.
    Sorry for the delay. The site was down.
  9. Trumpetrhapsody
    Trumpetrhapsody Member
    Fayetteville, AR
    Are these shim pools still up and running? I'm needing a 265, two 270's, and a 275.
    Thanks!
  10. snapper33
    snapper33 Member
    United States
    I would like to encourage that if you get used shims, and do not know the history, please demagnatize them just in case they were magnetized along the way.
  11. Trumpetrhapsody
    Fayetteville, AR
    Indeed.
    Found these from a guy locally, never-ye-mind
  12. adrian1
    adrian1 Active Member
    How are they demagnetised? Heat and a swift blow?
  13. TIMEtoRIDE
    De-Gaussed - - would the machine at the library that they used on VHS cassettes work ??
    Don't go heating them up.
  14. darkfibre
    darkfibre Member
    Perth, Australia
    Rotate a camshaft lobe past it at high speed.
  15. yamaman
    yamaman Member
    Staten Island, NY
    doesn't the motor do that on its own? what am I missing
  16. adrian1
    ?? If it does then what's the issue with them being magnetised??
  17. adrian1
  18. HirsuitHeathen
    South Jersey
    Ask and you shall receive: http://www.x-magnet.net/faq.html
    iwingameover: I never saw this thread after I posted in it, just got my notifications back...go figure.
  19. adrian1
    Yeah....seen that link...given that the shim receives heat and hammering in spades this is probably an urban myth.....be interesting if someone out there had a spare shim they could magnetise than apply mild heat/hammering and see if it still likes iron filings 8)
  20. HirsuitHeathen
    South Jersey
    For the sake of science I might have to go myth buster's on my old shims.
  21. skw1972
    skw1972 Member
    Milton Florida
    LOL! and will you report back on your findings? Now I wanna know too
  22. retread83
    retread83 Member
    Homossasa, FL
    I have 2 285's & 2 not marked from my valve adjusting. Checked the 2 not marked with my old micrometer,seem to be 285's.If someone has 2 frame neck reflectors, how about an even swap?
  23. Polock
    do not heat a shim, if you knew how hot to heat and how long to hold it at that temperature and how to control the cooling , you'd know not to do it
  24. RickCoMatic
    One of the Factory RECOMMENDED Methods for removing Valve Adjustment Shims is with a Mechanics Shop Magnet.
    I think it is safe to say that a Shim will not be magnatized in the short time that it gets handled during removal.
  25. skw1972
    skw1972 Member
    Milton Florida
    O.k now I gotta ask. does any one regularly use a mag tool?
  26. RickCoMatic
    I suppose those who have them, ... use them.
    The SnapOn Tool, ... telescopes and swivels.
    I've seen a few Home-Brew that were once Hidden Key magnets attached to the dowel of a wooden clothes hanger you get when you rent a Tux.
  27. skw1972
    skw1972 Member
    Milton Florida
    and here I was acting like magnets had the black plague or something. good deal, one less thing to worry about.
  28. snapper33
    snapper33 Member
    United States
    All: I posted and watched this develop. I wrote what I did due to what I was taught on this board elsewhere. I may have been wrong, but I absolutely trust a few of you who have told me to never magnetize shims....not arguing; just sayin'
  29. parts
    parts Member
    prescott valley az
    After fighting with hemo's and little drivers I gave the mag
    a shot. Best way to remove the shim IMHO.
    Bigfitz will very much disagree (and BF is really knows these motors) but in this case I think Ill have to stick with the mag.
    I've asked a few local shops and they all use a mag.
  30. bigfitz52
    No, I won't "very much" disagree, and although I still don't think it's a good idea; I too just recently noticed that in one of the factory books it does indeed say to use a magnet to remove them.
    However, in a different factory book, it cautions AGAINST the use of a magnet for the reasons I've always stated.
    So, honestly, I dunno. But since hemostats and a tiny screwdriver work fine for me, I'm going to stay away from the magnet. Maybe it is just an "urban legend" but I don't want to find out the hard way.
  31. doc2029
    doc2029 Member
    Richmond, Va
    I used a small pair of needle nose pliers to get my shims our and a small non-magnet flat head screw driver to pop them out of place. The hardest part for me was putting them back in.
