Vacuum sync finally
Discussion in 'XJ Technical Chat' started by maz43, Jun 29, 2011.
  1. maz43
    maz43 Member
    Detroit area
    After getting the valves in spec and bench syncing the carbs, I finally got around to doing a vacuum sync.
    I used a home made sync tool with 2 cycle oil in it and a YICS tool made from instructions on the forum.
    I got a little bit of 2 cycle oil in the motor getting the levels adjusted but all levels were set to within 1/2 inch of each other(the sync tool I made is 3 ft high).
    The result.......WOW!
    I didn't know these bikes pulled that hard.
    Thanks to the tips and how to write ups here, I actually did it myself.
    This is a great Forum.
    Maz
  2. HirsuitHeathen
    HirsuitHeathen Member
    South Jersey
    Man this is killing me I can't wait to button up the valves and sync them bad boys up. Congrats BTW!!!
  3. ThomasTX
    ThomasTX Member
    Beautiful, Crime-Free Grapevine, Texas
    maz43
    Any pics of your fab work on the tools? I'm working on some myself.
  4. ThomasTX
    ThomasTX Member
    maz43
    Which YICS tool did you build? I've seen a few versions here.
    Any pics of your fab work on either/both of those tools?
  5. maz43
    maz43 Member
    Detroit area
    The YICS tool was made according to Rickcomatic's specs.
    It works just fine.
    The "sync tool" was made with 3/16 clear tubing, 2 3/16 tees,some staples 4 3/16 restrictors and some "slightly used"plywood.
    It ain't pretty but it actually worked.
    I used 2 cycle oil filled up about to about half way up.
    It is very sensitive and a bit of oil got sucked into the motor before I got it on the map. I had to start the motor, see which tube was getting sucked up shut it down and adjust a few times before I could fine tune it.
