Best "gadget" tool I've purchased in a while
Discussion in 'Hangout Lounge' started by mlew, Jul 2, 2011.
  1. mlew
    I bought this BlackHawk 1/4 ratchet a few months ago and finally had a chance to use it durring a valve cover gasket job. It made the job of removing the bolts in the tight space very easy. It works just like a standard ratchet but when you twist the handle it will rotate the socket just like regular. It easliy saved me time and a few choice words. I would recommend one in everybodys tool box.
    BlackHawk GW-9946R twist ratchet.
    http://www.google.com/products/catalog? ... DQQ8wIwAg#
    Any other good ones purchased latley?
  2. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    I love gadget tools, well good ones anyway....I'm not sure looking at the link...does the grip rotate like a screwdriver causing the ratchet to...well...ratchet?
    jeff
  3. iwingameover
    iwingameover Active Member
    I've had one of those for awhile. But it has a T at the end of handle. Spin it and the socket turns. Great for where you can't get far enough to rachet.
  4. mlew
    Yes JeffK, when you turn the handle (clockwise) it turns the socket. Flip the lever and it goes the other way. It will work as a standard ratchet or twist the handle to turn the socket(or whatever attachment is on it).
    Long ago I had one with the "T" handle, it works the same way just a little more compact.
  5. bigfitz52
    OOOHH. Old guy need. Thanks.
  6. JFStewart
    JFStewart Member
    Ontario Canada
    Mac Tools ET120A test light. 6-12-24 volt. Won't hurt computer circuits. Has red led to indicate positive and green to indicate ground. Easy to test both sides of a circuit without disconnecting light. It is a bit pricey but all the guys in my shop got one when I used mine to trouble shoot a truck and they saw how useful it is.
  7. inet101
    inet101 Member
    Received one of those a while back for Xmas.....use it all the time. Thought "well thats nice" when I first got it........Set about for awhile then I started to use it.......Handy bugger it is.....
  8. MidnightSmoke
    MidnightSmoke Member
    Dahlonega GA
    Perfect for those bolts that:
    loosen up, take the ratchet off, turn with your fingers
    tighten up again, put the ratchet back on, loosen up again,
    turn with your fingers, tighten up again, ratchet back on....
  9. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    Just might have to pick that one up....
  10. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    Fyi; Stanley 3/8 drive version at Walmart $22. Twist handle EITHER direction and it ratchets to the current setting. Gonna get one soon.
