Quick Welding question.
Discussion in 'XJ Technical Chat' started by Gryfter, Jul 10, 2011.
  1. Gryfter
    Gryfter New Member
    Ok just a quick welding question.
    What do I need to do to weld on my exhaust.. Should I take the entire exhaust off or Can i just weld the muffler back on without taking the exhaust off.
  2. john_supra1990
    john_supra1990 New Member
    i would remove it
  3. SecaSuca
    SecaSuca Member
    NW Oregon
    you can leave it on there but you are gonna unhook your battery if you are using electricity to weld it. Don't wanna fry anything.
    It may be hard to do without getting spatter or messing up paint and chrome bits.
  4. Libertas
    Libertas New Member
    SL,UT
    Unhook battery, unplug TCI. Tack weld on the bike, then take it off to finish welding.
  5. badfish502
    badfish502 Member
    Id use a MIG w/0.23 wire and 25/75 gas, if i couldnt get that id use an oxy/acetylene torch.... A stick welder with little rod like 1/16" might work on dc
    good luck
    Jay
  6. Gryfter
    Gryfter New Member
    tacked it up no prop =) cheers
