my carb screws are 7 turns out
Discussion in 'XJ Technical Chat' started by simusix, Jul 13, 2011.
  1. simusix
    simusix New Member
    help
    the only way I can get my xj750 seca to idle smoothly is tgo have all carb screws 7 turns out , have balanceds with yics tool and color tuned ( mixtutre is correct on color tunes), any idea why idle screws have to be out this far ?.
    pilot jets wrong ??
    any help would be cool
    cheers simon
  2. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    4 screws? Pilot screws.... theres also your idle adjustment screw which is the knob in between 2 + 3!
  3. wizard
    how clean are those little old passages down there ?
  4. simusix
    simusix New Member
    I could understand a passage being blocked in one carb if that carbs mixture screw was a large number of turns out or in , but all 4 carb mixture screws have to be around 7 turns out , with yics tool installed and colortunes installed in two carbs at once seven turns out is where the mixture is correct, so is unlikly that all 4 carbs passages are blocked.
    I have cleaned out carbs according to forum readings on this site.
    do you think maybe that I have aset of carbs of a non yics model with differnt pilot jets ?
    this bike has never run right since I bought it so maybe has wrong carbs
    on it?
    thanks simon
  5. simusix
    simusix New Member
    can remember ,,, is turning out making richer or weaker ? cheers simon
  6. hogfiddles
    It is possible, then, that you may have a set of carbs on it from a 650. The bodies are the same, but the jets are different size.
    Model Fuel main Fuel Pilot Air Main Air Pilot
    XJ750 120 43 80 205
    XJ750 Police 118 43 80 195
    XJ750RL (‘84) 106 40 or 41 70 225
    XJ750E-II 102(2/3)
    105(1/4) 40 70 225
  7. hogfiddles
    Hmm... no matter what I do, it won't come out right. If you need me to translate it, I will try. Basically, tell me me exactly which bike is yours and what the numbers are supposed to be. Of course, if you're really good at figuring out spacings and can recreate the table, lucky you! :)
    Dave Fox
