Rear wheel ball bearings
Discussion in 'Hangout Lounge' started by Pattheswede, Jul 25, 2011.
  1. Pattheswede
    Pattheswede New Member
    Need edvice!!
    Hi
    I need new ball bearings to my rearwheel. But as they mounted 1 from each side and a tube between, I can't find a good place to hit it and get it out? Besides the only place to put a hit is a small piece in the center of the bearings.
    Anyone knows if I need a special tool, or how to do?
    br
    Patrik
  2. mlew
    A strong flat screwdriver will start the process. Use it to catch the edge of the bearing and hit it a few times to start pushing it out. Once its out enough use a brass punch to get it all the way out. Be sure to remove any snap rings before starting.
  3. stinedvd
    stinedvd New Member
    I've replaced about three wheel bearings using a concrete anchor like this one from home depot
    Concrete Anchor
    Just crank it down in the bearing and hammer it out thru the other side using a punch. Sometimes, they can be really stubborn. Spray the outside of the bearing down with PB Blaster or the sort to help lubricate it when it starts to move.
    For installation I use one of the old bearings and a piece of wood to hammer it back in. Make sure it starts straight and be sure to clean the inner surface that the outer part of the bearing will press into.
    Hope that helps. I'm sure there are all sorts of procedures for wheel bearings.
  4. Pattheswede
    OK, thanks. Will try today again. Will also see if I maybe have an concrete anchor for use.
    Really thanksful for your quick answers!
  5. lostboy2
    lostboy2 Member
    Crimora, Va
    If you haven't tried Kroil, then now is a good time to give it a try.
  6. iwingameover
    iwingameover Active Member
    A blind bearing puller works wonders. If you're near me (baltimore, MD) you're welcome to bring your wheel by and in about 5 minutes we'll have them out.
  7. Pattheswede
    TNX for all advice!
    Now it's out and new ones in!
  8. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    I don't know if this idea will work for our Yamaha's but on a BMW the mech used 2 propane torches to heat the 'aluminium' that surrounds the bearing. Just a thought.
  9. RickCoMatic
    Buy a 9-Inch "Line-up Tool".
    Remove the Splined Hub.
    Drive the Bearing out of the Hub.
    Collect the Spacer.
    Drive the other Bearing OUT the opposite way.
  10. Pattheswede
    Well, in this case the secret was to start punchin out the opposite one first, after that I had plenty of room to get the other out :)
  11. schmuckaholic
    California
    Boy, I'm going to have to start going that Bearing Replacement writeup sooner than I thought... :D Chacal sells a tool for this, doncha know.
