Motion Pro Shim Tool???
Discussion in 'XJ Technical Chat' started by RobDrech, Jul 29, 2011.
  1. RobDrech
    RobDrech Member
    Middletown, CT
    Any good?
  2. mlew
    Mine works good, no complaints
  3. RobDrech
    RobDrech Member
    Middletown, CT
    sweet thanks!
  4. bigfitz52
  5. snooker
    snooker New Member
    I used the Motion Pro tool I ordered online. I followed BigFitz's advice about mounting the tool but try and try and try again I could not get it to hold down the bucket.
    Looking at the casing around the bucket I could see that my tool was making scratch marks just outside of where it could contact the bucket. So I put the tip in a vise and bent it ever so slightly outward, (actually about three micro-adjustments) and then it started to work. If you try to "adjust" your tool, be super careful because the tool is a brittle cast metal.
  6. Smooooth
    Smooooth Member
    Syracuse, NY
    Cable Tie!!!! Cheap and very easy.
  7. bigfitz52
    #12 house wire is safer than a cable tie if you insist on going that route.
  8. waldo
    waldo Member
    San Jose, Ca. 95125
    And a lot faster
