AGM Replacement for 12A-A
Discussion in 'XJ Technical Chat' started by crunchie, Aug 2, 2011.
  1. crunchie
    crunchie New Member
    XJ Dudes and Chicks,
    The battery in my '82 550 Maxim hasn't made it quite two years according to the date stamp burned into it, and although it appears to be a cheap battery (it came with the bike when I bought it) I would like to replace it with an AGM battery for all the reasons one would want to do that.
    Is there an AGM replacement for the 12A-A that anyone has used on an XJ 550 with success? There is no direct cross reference from that battery model to an AGM in anything I can find.
    The first reply in this post below suggests an EXT15L might work:
    http://www.xjbikes.com/Forums/viewtopic ... +12aa.html
    However I'd like to see if that's exactly true before I plop down the cash at the local farm and barn, or if I have to get one of these online.
  2. SecaMaverick
    SecaMaverick Active Member
    Northeast Ohio
    Try clicking the XJ4Ever link at the top of the webpage, and go to our resident parts guru's catalog pages. I ordered an AGM battery from him last year for my '81 550 Seca, and I love it. Fits like a charm, and the higher output cranks the starter significantly faster.
  3. crunchie
    crunchie New Member
    Ah, here it is from this page, though there is no battery number designation given:
    http://www.xjbikes.com/Forums/viewtopic/t=17198.html
    for all XJ550 and XJ650 models:
    HCP1425 OEM original style STANDARD-PERFORMANCE WET BATTERY...
    HCP10455 OEM replacement style HI-PERFORMANCE WET BATTERY...
    HCP10401 Aftermarket HIGH-PERFORMANCE AGM BATTERY. This is an Absorbed Glass Mat style battery and is already filled with the acid-and-water mix and fully sealed, making it maintenance free for the life of the battery. NOTE: this battery is approximately 2mm taller than an original battery, and may require some slight modification to your original battery box for terminal attachment clearance on some models. Comes with a set of terminal installation bolts and nuts. 12 volts, 12 amp-hours, 180 CCA rating.
    $ 74.95
  4. pygmy_goat
    pygmy_goat Member
    Ann Arbor, MI
    I think all the AGM batteries are good quality--there doesn't seem to be a crappy option like there is for the conventional batteries.
    I had one for a while and I was really happy with it. But I found that the relatively weak electrical system on the bike has a tendency to ruin batteries (this could be my fault due to not enough maintenance on the wiring...but I don't think so), and it's easier to play with $35 conventional batteries than $75 AGM batteries, even if they're better (which they are).
  5. Altus
    Altus Active Member
    London, Ontario
    XS Performance makes an AGM battery for the 550's - it's part #61-2026 -- CBTX12AHL-BS
    I've got the similar battery in my 650 for the 2nd year now and it's been spectacular. You do need a proper charger for AGM batteries though - I got one that's also a maintainer, and all good so far.
