Saddle bags
Discussion in 'XJ Technical Chat' started by doc2029, May 23, 2011.
  1. doc2029
    doc2029 Member
    Richmond, Va
    Suggestions on what ones fit/work well with an '82 XJ650 J? I am looking to get some but thought I'd ask you guys what you use, what has or has not worked for you.
  2. shooter05
    shooter05 New Member
    Newark,Ohio USA
    I have saddlebags and trunk and fairing. I have been trying to find more info myself. There doesn't seem to be any info on it.
  3. BillB
    BillB Active Member
    Tulsa Oklahoma
    oops
    oops
  4. BillB
    BillB Active Member
    Tulsa Oklahoma
    I'm still working on these to fit right but, with a little imagination
    and rigging you can get most any bag to work right.
  5. ColoradoDan
    ColoradoDan Active Member
    Longmont, CO
    I have the Moto Classic saddlebags from Amazon. The same ones you can find at Walmart.com. About 60 bux. Seem to be the low cost ones you can find anywhere online, but I like them. They are basic backpack material with velcro straps and plastic buckle attachments. The setup recommends placing them over the back seat, but I attached them under the seat so they hang a little lower and let me have my bungy net on the back seat still. I am trying to attach the most recent pic of my bike that shows them in action, but it won't take so I'll do it on a later post.
  6. MoralDK
    MoralDK Member
    Spokane
    I got these at Cycle Gear for $50. They seem to fit and work well.
  7. Bomonghani
    Bomonghani Member
    Indiana
    Has anyone looked into relocating the rear turn signals to make room for larger bags? I've been considering modifying my break light, adding the led turn signals to the side and getting the led break light\turn signal license plate holder for extra visual.
  8. pbjman
    pbjman Member
    Algonac, MI
    HMM, I thought I posted to this thread yesterday but it's not here today...
    Anyway I had written about some leather throw-over saddlebags I bought from a dude on CL.
    I assumed I could put the seat over them but no! The big strap would have to be cut up for the seat latches to work and the blinkers would have to be moved rearward. I figured I could use a pc of flat bar steel about 1" by 5", with a hole drilled in each end, and bolt it to the existing blinker mounting tab. The steel bar would be mounted horizontally with the blinker re-mounted toward the rear of the bike. (Note that the blinker mounting bolt is hollow and the wires run right through it so you'll have to disconnect & reconnect the wire if you plan to do this.)
    But for now the bags are just sitting in my garage and if I need them I'll just throw them over. It works fine but I don't like them laying over the queen part of my seat.
    I'll try to post a pic a bit later after work.
  9. MaxXJRidrSevenFiveOh
    MaxXJRidrSevenFiveOh New Member
    Wash State US of A
    I made my owne
  10. MoralDK
    MoralDK Member
    Spokane
    Easy open, waterproof, roomy, won't collapse....nice!
  11. MaximumX
    MaximumX Member
    Ottawa, Canada
    How bout a little something from Samsonite?
  12. doc2029
    doc2029 Member
    Richmond, Va
    I ordered these http://www.amazon.com/gp/product/B000RN4FK6 yesterday. They should arrive today, so I'll see how they fit tonight! The are the Motogear Motorcycle Saddle Bags got them on amazon for 49.99 and free second day shipping because I am a 'prime' member. They could be the same ones that MoralDK has.
  13. pbjman
    pbjman Member
    Algonac, MI
    re: maximumX
    That pic gives additional meaning to the phrase 'carry-on luggage'.
  14. MoralDK
    MoralDK Member
    Spokane
    doc2029, those aren't the same as mine...they're better. Mine (from Bilt) don't have foam panels. These foam panels could provide insulation for hauling cold/hot drinks or food. Also, the straps for mine are attached at the top edge of the bags. It looks like yours attach a few inches below the top of the bags. So, if you strap under the seat, the bags should ride higher. I'd like that. I may order those.
  15. doc2029
    doc2029 Member
    Richmond, Va
    Cool, that is my plan to run the straps under the seat. I'll take a few pics tonight and figure out how to post them here.
  16. goneape12
    goneape12 Member
    Cincinnati (NKY)
    Doc,
    Did ya get the bags on last night? I'm curious to see how they look.
  17. doc2029
    doc2029 Member
    Richmond, Va
    Yeah I still need to do some adjusting. I'll actually upload pics tonight. I think though the straps running under the seat are going to be a bit of a pain. Because of the spacing of the straps and the seat latch, it was tricky getting the seat on and locked in.
  18. doc2029
    doc2029 Member
    Richmond, Va
    Here are two pics of my new bags
  19. goneape12
    goneape12 Member
    Cincinnati (NKY)
    Thanks for the pics Doc, any chance you could take some a little farther back? I'd kinda like to see what they look like overall with the bike. Other then that, what's your overall opinion on them? May try and buy them this weekend.
  20. doc2029
    doc2029 Member
    Richmond, Va
    I like them they look good on the XJ. They hold a fair amount of stuff and this far just lugging my laptop for work, rain gear and lunch, they work great. I put some books in them on the test ride and it worked quite well. It is a bit hard to get the seat back on but it can be done. I ran one of the straps under the frame, and one behind the grab bar behind the tail light.
    The directions are not clear but there are two grey pieces that fit inside of the bags they velcro in and are what gives the bag their ability to hold their shape. Honestly I don't think you can do better for the price.
  21. Bomonghani
    Bomonghani Member
    Indiana
    Oh! And change the lighting, and maybe use a fish lenses and maybe a get a hottie to straddle the bike??? J/K
  22. doc2029
    doc2029 Member
    Richmond, Va
    Hope this gives you a better idea of how they look....
  23. pbjman
    pbjman Member
    Algonac, MI
    Are your rear blinkers in the same position as mine? Yours must be crammed against the back of the bags?
    I wish mine were back further, would make bags easier.
  24. doc2029
    doc2029 Member
    Richmond, Va
    Yes they do sit up against the signal lights. But being soft bags you get some flexibility. So far it has not been an issue for me. My bike is stock execept for handle bars, which as soon as my grips and throttle tube ship from xj4ever, I'll be putting on a set of stock bars!
  25. brianf408
    brianf408 Member
    Do you have a pic of your brackets to hold the boxes on? I'm picking up a set of almost the exact same boxes for my bike.
    Are those the waterproof models?
