oh man i am fed up
Discussion in 'XJ Modifications' started by anton80, Aug 8, 2011.
  1. anton80
    anton80 Member
    concord ca
    so got my carbs back today put them on to no surprise the bike didn't fire but with a little help i got them to.. and after a while a weird squealing started coming from the carbs dose anyone have any idea what that can be??? its a 85 xj 700 with mikuni xj 750 carbs i am getting really frustrated with this. i have pods on the carbs and open exhaust if that helps for anyone to explain the weird squealing...
    thank you everyone
  2. skw1972
    skw1972 Member
    Milton Florida
    has the bike ran with this set up? wondering
  3. Alive
    Alive Active Member
    Queensland, Australia
    If you could, might be an idea to get it running right with a factory setup then change one thing at a time to make sure it keeps running properly.
    Then you know where the issue is as you swap stuff over.
  4. mlew
    I have heard a squealing noise from my carbs when the choke is on. Its more like a high pitch whistle though. Look to see if those pod filters are blocking any of the air passages in the end of the carbs.
  5. anton80
    anton80 Member
    concord ca
    hey guys i cant go back to stock because i do not have the stock stuff at all i got the bike as complete garbage with a vision of making into a cool bobber the carbs that are on the bike came with it and i have no stock air-box wish i did i ordered one but was the wrong one shucks and cant fine the one i need i have thought about making one but dont know the dimensions to custom make one...
    skw yes the bike ran with the set up until i had the carbs rebuilt
    Mlew i will check that tomorrow thank you
  6. MaximumX
    MaximumX Member
    Ottawa, Canada
    Is it an air-cooled Maxim 700 or liquid-cooled Maxim X?
    Air-cooled should have Hitachi carbs. Mikuni were fitted on the Maxim X... I don't know how much of a difference it would make, but you're a long way from stock if you've got Mikuni's on an airhead.
  7. AlbuquerqueChoppers
    AlbuquerqueChoppers Member
    Albuquerque New Mexico
    Does it whistle when you slam the gas, or mostly when you let go? Sounds like the engine wants air and it is playing the flute to get it in the engine (Butterfly is closer to closed than open, for proper idle rpm)
    Make sure the slides move easily, I would spray a blast of wd-40 into each carb and try to loosen anything binding...one of the slides could be stuck in a down position and that would choke air causing a whistle as well.
    Pods and open exhaust have NOTHING to do with it, so don't worry on that front. It should run just fine, but it would need to be bench balanced at least to get close to running tune. I used a sewing needle to get the butterflies even on the bench tune and sure enough it was almost spot on upon firing it up. Keep info coming and you will get it figured out soon enough, there are enough people that can fix stuff here, just don't get lost in the comments of the people that talk about fixing stuff, lmao!! GL
  8. anton80
    anton80 Member
    concord ca
    thanks Albuquerque i am going to go home and do that today i forgot to check the butterflies before i put the carbs back on OOOOOP's
    ill keep you guys updated
    thanks again
  9. anton80
    anton80 Member
    concord ca
    ok this might sound like a real dumb thing to ask but how do i find a vacume leak on my bike its coming from the left side of the bike but i am having a hell of a time locating it??? and trick is appreciated...
    im not even getting it to fire rite now because of it it turns over but then its like the starter slips and it makes the cherping sound while i am turning her over... its sucking air in somewhere but where HELLLLLLLLLLLLLLP
  10. Mad_Bohemian
    Mad_Bohemian Active Member
    Ravenna MI
    It needs to be running to check for a vacuum leak. You can take some carb cleaner, or some guys use propane (I think it's propane... someone will correct me if I'm wrong :D ) and spray around the suspect area while the bike is running. First make sure all your manifold bolts are tight. Visually inspect your manifold boots to look for cracks or splits. You will need to make sure the butterflies are at least bench-synced or you can spend hours trying to figure out wtf is wrong...
    I know it's a pain pulling the carbs on and off, but 'm gonna bet that by the time you're done you be able to get 'em off and on in lest than 10 min :D (been there.. done that! lol)
  11. TIMEtoRIDE
    Use a can of Ether (starting fluid) and a red tube from a carb cleaner can for precision work locating the vac leak.
    Did you recently do an oil change?? I only ask because you complain about your starter clutch, and if you put in some "energy conserving" car oil.
    To make your bike quiet so you can listen better for this leak - - wrap a couple old bath towels (dripping wet) around your mufflers, hanging off the ends.
  12. anton80
    anton80 Member
    concord ca
    thanks guys i will try that tomorrow and follow up with my progress
  13. anton80
    anton80 Member
    concord ca
    with no luck i tried all the tricks you guys have told me and i still cant find the leak it almost sounds like it coming from inside the carb like its trying to get air but really cant i might have to take my carb's off again and bench sync them... what could it be inside a carb???
  14. skw1972
    skw1972 Member
    Milton Florida
    I know this is way out from left field and stupid to even ask but are the carb hats tight? diaphrams set in the grooves good?
  15. hogfiddles
    did you replace all of the vacuum tube caps on the carb-to-manifold boots? other than the one that has the vacuum tube to the petcock)
    Dave
  16. anton80
    anton80 Member
    concord ca
    ya caps are new everything is tight... but i think i just had a break threw i think i have a leak in the top end cylinder gasket now what?????
  17. skw1972
    skw1972 Member
    Milton Florida
    you spraying WD-40 or something at the cylinder gasket area while running or how'd you determine that?
  18. anton80
    anton80 Member
    concord ca
    i put my hand around the carbs and it feels like its blowing air out rite at the top end and i sparayd wd-40 on it and it bubbles a little im gona take a closer look today ill keep everyone posted but im almost 99% sure thats what it is
  19. anton80
    anton80 Member
    concord ca
    i worked on my bike for a little bit today finally got the clutch set but it still dies when i put it in gear, grrrrr i am guessing that when i chopped my wires up i failed to tie the wires together on the neutral switch.
    can anyone tell me if that would cause this??? that the bike would just die as soon as i put it in gear
  20. parts
    parts Member
    prescott valley az
    you just had your carbs rebuilt. pull the hats and the bowls
    off and make sure all the jets are in place and in the correct
    location.
    in the future you may want to do them yourself.
    hope this helps.
  21. mirco
    mirco Member
    LaGrange Ohio
    You chopped your wires up? If it is dying when you put it in gear it could be that you didn't by-pass your side stand safety switch correctly.
  22. wamaxim
    wamaxim Active Member
    Vancouver, USA
    Dude! This could have been fixed long ago if you had come clean!
    If you want help solving problems LIST EVERYTHING YOU HAVE DONE TO THE BIKE INCLUDING THE LAST THING(S) YOU DID BEFORE IT BROKE!!!!!
    This was a post on another forum I frequent that sums it up well:
    "Because so much of the finer details get left out in posts ... Running s**t fuel, Have a Remus exhaust, fiddled with this and f***ed with that get left out of posts, one somewhat has to read between the lines"
    Loren
  23. anton80
    anton80 Member
    concord ca
    Wamaxim- Ill remember that next time so i take that you agree that i need to by pass the neutral switch, i Will work on that today and ill make sure i post every last detail from now on...
    Thank you guys for your help hopefully this will fix the problem and i will post pictures along with a full thread on what i did thanks
  24. anton80
    anton80 Member
    concord ca
    im getting real close to giving up i had my carbs rebuilt by a shop and now i cant get the bike to fire without starter spray. besides the bad needles and seats before i took them in the bike would fire first push of the ignition what the heck is going on.
    P,s update coming tomorrow on the kickstand switch but have to get the bike running again first
  25. anton80
    anton80 Member
    concord ca
    ok i have a update i worked on my bike last night with some help from my neighbor and a few beers we found the problem of the chirping, when i installed the the new carb valve i didn't get the surface cleaned enough there was a still a piece of the old gasket on there my beginer mistake you live and learn.2 we also got the kickstand switch grounded out so now my bike will go ill be doing a test ride today and see how she runs.. i would like first off to thank everyone on here for their help and i look forward to future issues and so on... thank you every one
    next is adjusting the valves scares the sh$% out of me
  26. doc2029
    doc2029 Member
    Richmond, Va
