Should I buy xj650 w/second gear issues??
Discussion in 'XJ Technical Chat' started by maybe4, Aug 15, 2011.
  1. maybe4
    maybe4 Member
    Chicago Area
    I am thinking of buying another 1982 xj650 on craigslist. The author states "the bike has second gear issues - Just don't push it too hard and it is fine"
    Is this kind of problem fixable? Yes I know everything is fixable, but would it scare you experts away?? I'm asking because the price is right, might even be worth it just for parts?? He says it runs "great" otherwise......
    what do you guys think??
  2. TIMEtoRIDE
    From what I've read, it's a bent shift fork, or, the place where the "dog" contacts the gear is rounded. I bought my first 900 that way, and paid to have it fixed.
    It all comes down to price, and what are you going to do with another 650 ?? (Plan? - there aint no plan!) :p
  3. maybe4
    maybe4 Member
    Chicago Area
    thanks TtR.....you're right is does all come down to price but it's nice to know that it is a fixable problem.....I definately don't NEEEEEEED another XJ - but I kind of want it anyway :)
  4. BillThyCat
    BillThyCat Member
    Ottumwa, IA
    Does that fork issue also cause slipping in 2nd gear? My bike, if you are hard on the throttle in 2nd it will slip until you let off the gas and then get back on it, and then it's fine, 2nd gear is the only gear it does it in. (I don't normally drive like that, just had seen it the one or two times I have done it).
    Normal driving it's fine, never had any issues with shifting, slipping, etc. Just curious if mine may have the same issue.
    BTC
  5. TIMEtoRIDE
    slipping is the clutch. Worn out - wrong oil - cable adjusted wrong.
    On the 2nd gear problem, it "Pops" back into neutral - RPMs go soaring.
    I developed a habit of a double-shift to 3rd.
  6. BillThyCat
    BillThyCat Member
    Ottumwa, IA
    Ah ok, cool. Thanks, just wanted to make sure I wasn't chasing the wrong problem. Rebuilding the clutch is one of my things to do.
    BTC
  7. midnightmoose
    midnightmoose Member
    York, PA
    Do any of us really NEED another XJ? I just came across an 85 maxim x that i didnt NEED, but I couldn't resist...its in great shape and the price was right. And just like when I first saw my other bike, it was love at first sight, I just HAD to have it!!! So now I have two!!! :D
  8. Polock
    guess the bad one, this popped out of second maybe 12 times that i know of. the gear that ate it was a brownish blue color, the jagged black stuff is melted steel. as the drive dogs wear and round off they come out of engagement and the gear pushes into the shift forks, they have no where to go
