Electrical Issue!!!
Discussion in 'XJ Technical Chat' started by SteveBMaxim750, Jul 10, 2011.
  1. SteveBMaxim750
    SteveBMaxim750 New Member
    Hi there,
    I got a Maxim 750 1982...I have been restoring it as the previous Owner did not take very good care of it...I have been painting it the frame..yada yada...I am in the middle of putting it back together...I got it put together went to start it..it started now..every thing was working fine..then when I went to turn the signals on they came on but did not flash, so I saw a few wires that were crossed in the signals I straightened them out...Now I am getting nothing at all but a headlight...it wont start and I have no signal lights, brake lights... but all the fuses are good...Anybody have any ideas please...=( I was on here before and you guys are allways awesome!! Any help is greatly appreciated!!
    Thanks again
  2. SteveBMaxim750
    Ok ...now I have it starting but still no electrical???? what the hell man??? this bike is trying to drive me crazy!! but I am DETERMINED to get it on the road!! :?
  3. SQLGuy
    SQLGuy Well-Known Member
    Do you still have an original fuse box? If so, you should probably replace it.
    Since you're painting the frame, have you painted any grounds? Make sure that any wires that connect to the frame for ground still have a good ground. I think the turn signals fall into this category (using frame ground near where they mount).
  4. lostboy2
    lostboy2 Member
    Crimora, Va
    I had a problem with my wires a while back on my 82 xj 650 and it was a grounding issue. I also switched out the old glass fuse block with a blade type. I haven't had a problem since. It is a great inexpensive upgrade that you will be glad you have done.
  5. SteveBMaxim750
    Hi GUys my hubby wanted me to come online and quickly thank everyone for all their help!! he recentyly started a landscaping business and hasnt had a spare moment in over a month!! He managed to get all the lights and everything that was not working fixed...he bought a new battery and tires and some other stuff too... I am actually online today to looking for any information on bleeding the brakes...he just bought a new Caliper and pads...and he did some other stuff to the brakes and now needs to bleed them but is having a hell of a time... So I will keep crusing thru the forums for some answers!! And again you guys are all absolutely Awesome!! Your help and advise and even just going thru the forums has been so helpful!! YOu guys are all rock stars!!! I am going to try to post some pics of the bike he is working on...and it is actually going for paint on the long weekend. My god father is a muscle car...and any kind of carreally fanatic and his very good friend is a professional painter and is going to do a custom paint job on the bike for my hubby so I will definately get some pics posted!! Thanks again guys!!!
