air/ fuel ratio screw??
Discussion in 'Other Motorcycles' started by himmetal, Sep 10, 2011.
  1. himmetal
    himmetal New Member
    kuna, Idaho
    i have a set of mikuni carbs on my gs450 and it is running lean and i need to adjust the air fuel mixture. is the adjustment screw hiding under a metal plug because of the epa regulations??? help???
  2. Ravenz07
    Ravenz07 Member
    The metal plug needs to be drilled out, but be careful. You dont want to go too far and hit your pilot screw.
  3. himmetal
    himmetal New Member
    kuna, Idaho
    thank you! Is that the the only obvious metal plug on the carb?
  4. bigfitz52
    Probably. At least the only one you'll see looking straight down.
    Are they CV's? (I'm assuming they are.)
    If so, the plug you're looking for is over the pilot (mixture) screw. If indeed they're CV's, they'll be very similar to this: http://xjbikes.com/Forums/viewtopic/t=31061.html The second pic in the article shows it clearly (with the plug removed.)
  5. himmetal
    himmetal New Member
    kuna, Idaho
    yes thank u!
    they are cv carbs
