Anybody know what this is?
Discussion in 'Hangout Lounge' started by HESH, Sep 19, 2011.
  1. HESH
    HESH Member
    Los Angeles
    [​IMG][/img] All I know is it's a 1983 Yamaha. $700 runs and needs some work. Haven't seen it in person. The owner doesn't even know the engine size. It's about 2 hours away so wanted to see if I could get some info from you awesome people on it before making the drive. The owner doesn't know shyt.
  2. pbjman
    pbjman Member
    Algonac, MI
  3. HESH
    HESH Member
    Los Angeles
    Thank you very much. Think I'll make the drive after work today.
  4. MiGhost
    MiGhost Well-Known Member
    Looks to be a Venture 1200 XVZ12TK, or Venture Royal 1200 XVZ12TDK
    V4 - 1200cc. Considered by some to be a bit heavy,and cumbersome, but a good general touring bike.
    Get some good picks, and measurements of the saddle bag guards for me. looking for a replacement for one of mine, and need the info.
    Ghost
  5. Rickinduncan
    Rickinduncan Member
    Duncan, BC Canada
    Also very prone to second gear problems. I know - I had one. Nice stuff - cruise control, self cancelling sigs, air suspension, intergrated brakes, radio pack and good acceleration - which is why 2nd gear usually failed! The panniers also detached and became your suitcases.
  6. MiCarl
    If you plan to ride it make sure 2nd gear is good. It's a major pull the engine and split the case fix.
    If the fairing halves, front fender and trunk are in good shape they're pretty much worth the $700.
  7. mlew
    Looks to be a 83 to 85 Venture. As the others have said, watch out for 2nd gear. I see some parts on there I want for mine. They are nice riding bikes, very comfortable on the open road.
  8. BonezOz
    BonezOz New Member
    Sydney, Australia
    Reminds me when I had an opportunity to pick up a 77 Goldwing for $600, shame I passed that one up....
  9. Dannymax
    Dannymax Member
    East central NY
    The Venture shares the same basic engine with the V Max but with different jetting and slightly smaller carb bores. Also the Venture does not have the V-Boost assembly.
  10. mlew
    Venture and V-Max have similar engines. Venture has about 95hp, V-Max around 140. So tell me why my V-Max gets better gas mileage, 5 mpg better. I ride the Max lots harder than the Venture.
  11. Dannymax
    Dannymax Member
    East central NY
    Just a guess but is it a horsepower to weight thing?
  12. MiCarl
    Your V-max doesn't have to push that huge fairing through the wind.
  13. cutlass79500
    lawrenceville georgia
    smaller cams also
  14. tcoop
    tcoop Active Member
    South Weber, Utah
    I just got my Venture back on the road. It is a little heavy at slow speeds but I still enjoy riding it. At $700 and if it runs good you almost can't pass that up.
