Petcok rebuild question
Discussion in 'XJ Technical Chat' started by patmac6075, Sep 25, 2011.
  1. patmac6075
    patmac6075 Active Member
    MKE
    I have a quick question about a petcock rebuild for an '82 XJ750 Maxim.
    Got it all cleaned and polished and started putting it back together (per Big Fitz's thread).
    The only thing I can't figure out (and didn't note when disassembling) is: "Where does the steel (I believe it's called a Wave) washer go? Does it go next to the Valve Body Seal (round rubber part with 4 holes) and under the selector? Or does it go in after the selector just before you install the selector cover plate?
    As always .... you're assistance in appreciated.
    P
  2. Bushy
    Bushy Active Member
  3. patmac6075
    MKE
    So it looks like the Wave Washer goes it AFTER the selector and before the cover plate.
  4. bigfitz52
    I covered it in the how-to; I just went back and looked. You had me worried for a sec.
