Rebuilt gas cap doesn't want to latch
Discussion in 'XJ Technical Chat' started by Massimo33, Sep 29, 2011.
  1. Massimo33
    Massimo33 Member
    Denver, CO
    Hi all, like the tag line says, I rebuilt my gas cap and when I went to reinstall it, it is so tight that I cannot get it to latch inside the tank. It won't seat enough for the latches to engage.
    Anybody ever have this problem? Any ideas?
  2. SecaMaverick
    SecaMaverick Active Member
    Northeast Ohio
    Did you use the original seal springs as-is, or did you replace them or stretch them before reinstallation? I have to press down on the cap while turning the key to latch the ears.
  3. Massimo33
    Massimo33 Member
    Denver, CO
    The only thing I replaced was the rubber seal, the other seal was badly cracked and worn. The springs looked to be in decent condition, so I didn't mess with them, as did the latch springs, although I did clean them up a bit, I didn't stretch them.
  4. bigfitz52
    And you are using the key to re-lock? It won't just press shut, you'll need to use the key; that's normal.
    Did you get the whole seal assembly, the rubber ring bonded to the metal "cup" thing?
  5. Massimo33
    Massimo33 Member
    Denver, CO
    Fitz, yeah I was using the key and pressing very hard to seal it.
    Also I did get the rubber seal assembly with the metal cup from Chacal.
  6. bigfitz52
    Is it maybe not happily aligned?
    What happens if you remove the fixing screw so it can "adjust its own position" a bit?
  7. chacal
    You may have installed the seal upside down...........
  8. Massimo33
    Massimo33 Member
    Denver, CO
    Fitz - even not mounted to the tank I can't get it to seat.
    Len - I'm pretty sure that it was mounted correctly
  9. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    I never trust anything anymore. (Sorry Len) but did you compare the old part to the new part. Some times we get parts with the right part number on the bag or box but the part inside may not be correct. You have to double check everything now these days.
    MN
