How the f##k do you remove the airbox?
Discussion in 'XJ Modifications' started by admiral.snelson, Nov 24, 2011.
  1. admiral.snelson
    admiral.snelson New Member
    London
    Hi Guys
    Got an 700 Maxim, how do I get the airbox out? Looks like I hvae to cut it out.
  2. bigfitz52
    If you remove the starter, the carbs, and the exhaust system, you can undo the front engine mounts allowing the motor to pivot forward and give you room.
    Don't cut it up; that way you'll have it when you realize you want it after all.
  3. admiral.snelson
    London
    What benefits are there to the airbox over K&N Cone Filters? I have 4 sitting in my garage which would look great on it, and improve airflow me thinks.
  4. maverickbr77
    maverickbr77 Member
    Lowville, New York
    just do a forum search for pod to get a whole lot of argument about it.
  5. Orange-n-Black
    Memphis Area
    I cut mine out, but it already had a big hole in it. The big problem with pods on these bikes are the constant velocity carbs. Some have had good results with velocity stacked pods which will still involve changing jets. Or you could get a decent set of round slide carbs for about 350.00 that are alot easier to deal with and handle air & exhaust mods better.
    May cost more than you want, but will be less of a headache.
  6. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    I don't know about the 700 Maxim, but there is no way to remove an airbox from a 1982 750 Maxim without removing the engine, I sat on my little bench turning the damn thing every which way, but to no avail. I removed the carb boots from the head and engine mount bolts, no help there. It seems Yamaha designed it to be removed after the motor was gone.
  7. adrian1
    adrian1 Active Member
    Uh Oh This looks like another Starter clutch thread LOL
  8. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Wrong! it's an airbox thread.
  9. skw1972
    skw1972 Member
    Milton Florida
    It is my experience LVSteve is correct I removed engine side carb boots, starter, headers, engine mounts to sag the engine forward, .... still cant get a dnam airbox in or out of a 650 Seca or 750 maxim. I did find a bike lif
    but Id rather go through what I went through to install one than go the pod trials
  10. adrian1
    Yes understood...what I meant was like the starter thread, there seems to be debate on whether its possible :wink:
  11. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    I get it now Adrian, you just didn't phrase it right.
  12. bigfitz52
    It's possible depending on the bike. It can be done on the 550s and we had a member that was successful using the same technique on I believe, a 700 Airhead, which is why I offered the suggestion.
    I don't think it can be done without removing the engine on most of the 650/750s, but I can't say for sure.
    Yes, the K&N "pod" filters will increase airflow, and that is exactly why they cause tuning headaches with CV carbs. These carbs need a finite, regulated airflow to produce the correct responses, if given an unlimited air supply they don't work well. As above, do a forum search for "pod filters" before you shoot yourself in the foot.
  13. chacal
  14. hogfiddles
    Once again, I will tell you how I get them out when I don't plan to pull the engine.
    I heat the sides and bottom of the square part, when the plastic is soft, fold it together and remove the airbox. After putting it back in, re-heat it and carefully unfold it and smooth it back out.
    Dave Fox
  15. skw1972
    skw1972 Member
    Milton Florida
    Thats actually pretty slick. And makes good sense too
  16. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    That's great if you have the ability to heat it, I don't, darn it.
  17. skw1972
    skw1972 Member
    Milton Florida
    walmart has a decent gun for around 30 bucks. But home depot has a porter cabe thats better for about the same or not much more. They have lots of uses, this is just one I never considered and I should have (duh) the primary use for mine is to heat and form PVC condiut. Great for stripping paint too.
    Got give it to Dave on that one for sure, bravo Sir
  18. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    I know how to heat it, don't have access to electricity, not allowed to use propane; working out of a storage unit.
  19. Polock
    dry ice and a hammer
  20. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    I was able to install an air box on my 83 750 Maxim. I'm sure I could remove it and re-install it if need be. You need to pull the carb manifolds and the front mounting bolts for the engine. I had just enough room to fit mine in. I wish I had taken some pictures of that. I just remember it all had to go in from the right side of the bike
  21. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    How come this(remove the starter, the carbs, and the exhaust system, you can undo the front engine mounts allowing the motor to pivot forward) reminds me of the instructions for replacing the #8 sparkplug on my Expedition (unbolt and remove the body a few inches from the frame)?
    Talk about pi** poor engineering......shame, just an absolute shame....I sold a 650 Zuk for exactly the same reason......I was going to restore it and when I found that a simple airbox removal was so involved, I decided to sell it for junk and move on to my next bike rather then spend a month pulling hair.
    HMS Nelson, you are far better off keeping your stock airbox but I'm feeling your pain brother......
    jeff
  22. parts
    parts Member
    prescott valley az
    If you really want to spend most of the riding season
    tuning your bike over and over by all means-the pods
    will LOOK great. you just won't ride as much.
    On the other hand. if all you want is more air flow pop
    in a k&n filter instead of the stock one. But check your
    plugs right away-you'll be adj the pilots right from the
    git-go.
  23. skw1972
    skw1972 Member
    Milton Florida
    Still dont see the need for "more air"
    My bike will hit 100+ EASY with the stock air box
    even if you got the bike without one (as I did) replacing it with the cash and labor is still less than the cash and labor of rejetting the rejet again and getting more jets to re jet again...................then there's the rain.
    that my 2 cents
  24. parts
    parts Member
    prescott valley az
    +1 skw1972.
    I put in a K&N(=lot'oair) on because it's a lifetime filter.
    But after have a bit of a time getting the plugs off
    lean I'll just put a stock replacement on the next xj.
  25. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    It's not important that I get the airbox out at this point anyway, I just wanted to see if I could get it out. When I remove the engine this all becomes MOOOOOOOOOOOOOT!!!!!
  26. skw1972
    skw1972 Member
    Milton Florida
    True. sorry lost track of the original thread I guess.
  27. hogfiddles
    Well, then heck.......If all you're tryin' to do is get the airbox out, take a hacksaw and cut the frame away.
    Dave
  28. BluesBass
    BluesBass Member
    Clementon, New Jersey
    Seeing as how I JUST disassembled my XJ650 this weekend, I struggled with the airbox with ALL motor mounts removed for a good five minutes before I said to hell with it and just pulled the engine. Hate to say it, but that MIGHT be the best answer.
    blackhawk7188 likes this.
  29. hogfiddles
    the best way is to pull the motor, the quicker way is to heat it as I mentioned before. the quickest way is to cut it as others have done. I DON'T recommend that way. However, I did break one bike that had an ingenious cut-job......what that guy did was carefully cut the square part off of the box. Then, when the box was out in two pieces, he attached a close-fitting inside lip all the way around the edge of the square cut. Then, from the outside had four small angle brackets - about half inch by half inch by 1/4 inch wide by 1/16 inch thick. One screw in each leg (two screws pe L-bracket) held the box together. Dis-assemble to take out or put in, and once in place, put the screws back in and tighten it up.
    Dave F
  30. KumanK
    KumanK Member
    Oceanside, Ca
    Just to hit on the original thought on K&N filters... DONT DO IT!!! Im a newb and I have learned in the month of owning an XJ that the airbox is key in engine performance. Unfortunately my XJ's frame was hacked up by the PO to a rigid and there is no room for the stock airbox. So I have to life with / attempt to perfect the pods. These guys know what they are talking about with this subject. Just do some research on this forum and you will see what kind of heart/head ache pods cause.
  31. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    I guess my question has been answered, remove engine before airbox, I had to find out for myself.
  32. 82650secamuffins
    82650secamuffins Member
    san francisco california
    yep , remove ..remove...remove....then remove somemore,then heat gun to the back ends of box preferably two verticle corners >{avoiding wiring harness
    then crumple up same area heated ..making this area more of a 'rounded' shape ..then wiggle out..get box lodged in tighter..swear, swear again maybe louder more profane this time..push box back into original position..reheat then while twisting pushing and pulling scrape deftly against any type of protruding metal across knuckles until bleeding ..swear once more and after perhaps one plus hours you may finally proclaim your airbox to be free..
    then return to bike as is necessary as hell.on your 650 seca
