***Brute Bobb Build***
Discussion in 'XJ Modifications' started by Alysiak00, Aug 26, 2011.
  1. Alysiak00
    Alysiak00 Member
    i might in the near future but as of right now it runs fine. The plugs aren't white so i know its not running lean and going to burn up the motor. i might still rejet later with a stage 2 or 3 over winter
    the only thing im in the process of right now is making butterfly baffles for the muffler tips. This will help with backpressure and give a little more resistance
  2. HirsuitHeathen
    HirsuitHeathen Member
    South Jersey
    Now that I would like to see Alysiak!
  3. Alysiak00
    Alysiak00 Member
    no problem. ive been taking pictures along the way. ill have a write up in a day or two about how its done!
  4. chrisjfrederick
    chrisjfrederick New Member
    Hey Alysiak. First off, fantastic job. I am working a lot of my bike modeled after your approaches. I had a question on what you did to paint your frame. Did you use the airplane remover on it first? Sand? or did you send it in to get blasted? Also, If you used the airplane remover on the frame, what did you use to remove the paint?
  5. barkriver2005
    barkriver2005 New Member
    I had a hive in the exact same spot
  6. Alysiak00
    Alysiak00 Member
    i actually just scuffed it up and wiped it down with acetone to remove any oil. by scuffed up i mean some sand paper. i used 80 and then 220.
    i didn't mind the minor grooves in the frame because i used a pretty thick paint. its the textured paint from autozone. its very thick and fills in pretty much everything while being extremely durable.
  7. Alysiak00
    Alysiak00 Member
    lol i thought the hive was startling at first but made for a good scare tactic with the girlfriend
  8. chrisjfrederick
    Makes sense. Did you have any re-fitting problems due to the thicker paint application? Did you add a re-finish or prime to frame before you applied the dura-paint?
  9. Alysiak00
    Alysiak00 Member
    there wasn't any refitment issues at all. i primed the frame with reformer which blocks rust and acts as a primer.
  10. ouchie
    ouchie Member
    Throwin' a woop woop yer way for a great build bruddah!
    Once I get my float problem straightened out and she's riding good I'll be doing similar project over the winter
  11. Alysiak00
    Alysiak00 Member
    right on! keep us informed on the process...pics are always welcome. if i can help in any way let me know
    its nice seeing older bikes being restored, revamped, and rejuvenated. (the three R's)
  12. HirsuitHeathen
    South Jersey
    Anything new?
  13. brisbob
    brisbob New Member
    hows the build going, looking forward to seeing the progress
  14. Alysiak00
    Alysiak00 Member
    lol hello my distant friends.....the build is still going good but a little slow due to the fun ohio weather and the holidays. Ive gotten her atleast running but not perfect.
    as of right now i'm gonna get a new battery and keep searching for a 550 airbox assembly thats not $200 lol.
    Im also starting to re wire the starter button to a hide away spot on the frame rail.
    Definitely pictures to come.....
  15. HirsuitHeathen
    South Jersey
    Word...getting mine tuned up and ready for a winter build...wish I had a little extra cash I'd do what you did, but rake the neck out a few degrees.
  16. Alysiak00
    Alysiak00 Member
    that would be sweet. I had plans of doing that but between cash, age of bike, and bike stance; I decided to keep the stock size because it keeps that vintage bobber compact look
  17. HirsuitHeathen
    South Jersey
    Yeah looks a lot like what all the Triumph bobbers look like these days on ChopCult.com
  18. Alysiak00
    Alysiak00 Member
    those bikes have always inspired me. I love working on this bike but i've had a few things come up.
    -got engaged
    -keep working on my new saltwater tank build
    -needed truck fixed
    -stupid odds and ends
    -a think called "life" happened lol
  19. Alysiak00
    Alysiak00 Member
    okay so a little update. I FOUND A NEW AIRBOX!!!
    you would never guess how hard it is to find a flippin airbox for these things. Apparently the xj550 is like one in a million and everyone wants $150 for an airbox.
    I came across one on ebay that was up for 27min and i bout it. $23.99 with $11 shipping. Bingo
  20. bobbytheblack
    bobbytheblack Member
    Seattle, WA
    So some picture updates soon...
    You had the most intense build thread EVER, then you stopped. Its like if George Lucas stopped production on Star Wars after Luke crashed into the swamp...
