Forced air intake system
Discussion in 'XJ Modifications' started by theadbrewer, Jan 15, 2012.
  1. theadbrewer
    theadbrewer Member
    Roseville MN
    Can anyone see a problem with a forced air intake system with CV carbs??
  2. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    It's what Yamaha used on the XJ Turbo.
  3. chacal
    Making sure that the carb is completely pressure-sealed may be the hardest trick to accomplish. The turbo carbs have o-rings on the choke plunger shaft, special washers on the throttle shafts, and uses an o-ringed (rather than gasketed) float bowl and intake manifolds. There's a pretty good diagram and explanation in the factory service manual for the 650 Turbo that illustrates and explains the changes to the carbs vs. normally-aspirated carbs.
  4. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    Or you could use a draw through system. Simple and effective. One carb to tune.
