These are My Valve #'s/ Check Please
Discussion in 'XJ Technical Chat' started by ck0724, Jan 18, 2012.
  1. ck0724
    ck0724 New Member
    Ok, Here are the numbers I got last night, Can someone please check my numbers
    Exhaust
    1).004 Shim#250 .1016mm = .10 Need # 240
    2).005 Shim#255 .127mm = .13 Need # 250
    3).006 Shim# ??
    4).002 Shim#270 .0508mm = .05 Need # 255
    Intake
    1).0025 Shim#285 .0635mm = .06 Need # 280
    2).003 Shim#280 .0762mm = .08 Need # 275
    3).001 Shim#280 .0254mm = .03 Need # 270
    4).002 Shim#290 .0508mm = .05 Need # 280
    Does this look correct?? And if so, It appears I can swap 5 of them around leaving me with an extra #290,285
    Is anyone interested in swapping these for #240,275??
    Thanks In advance!!!
  2. dmccoach
    dmccoach Member
    NE PA
  3. ck0724
    ck0724 New Member
    That chart has me wayyyyy out of what i figured... i may be entering it wrong.... are my calculations wrong?
  4. ck0724
    ck0724 New Member
    nevermind , i figured it out
  5. bigfitz52
