Carb Diaphragm Replacement
Discussion in 'XJ Technical Chat' started by junkmn, Jan 30, 2012.
  1. junkmn
    junkmn Member
    Colorado
  2. dmccoach
    dmccoach Member
    NE PA
  3. schmuckaholic
    California
    (shrug) Works fine here.
  4. dmccoach
    dmccoach Member
    NE PA
    It's the darndest thing -- I can't get any of the sites page including the home page to load... :?
      File size:
      29.2 KB
      773
  5. TIMEtoRIDE
    The site worked for me - - how much glue to make them work on a Venture Royale (pain)
  6. schmuckaholic
    California
    What caught my eye is that they say the "tire can't come off" -- if you can put it on, it can bloody well come off!
  7. junkmn
    junkmn Member
    Colorado
    Doubt its gonna build enough pressure to force it off. If worried, tie it on from the underside with some small zip tie or a fine gauge insulated wire.
    A much cheaper alternative than others I have seen.
  8. xjlenordski
    xjlenordski Member
    Dubvegas, Australia
    I have replaced two of mine & they work fine.
    $20 each & only $3 postage to Australia!!
    Sure beats the shite out of $150 for OEM!!!
  9. MiGhost
    MiGhost Well-Known Member
    Smuckaholic.
    They are square shouldered with a pressure fit, and under normal operating pressures they will not roll off the lip. You would have to stretch the mounting shoulder to get it to go over the lip on the slide.
    Ghost
