two XJ550 maxim engines being parted out
Discussion in 'For Sale, Trade/Swap, Wanted' started by hogfiddles, Feb 21, 2012.
  1. hogfiddles
    Since there have been no takers on these two engines, I am going to part them out.
    I am going to harvest the shims for myself, but any other parts are up for grabs. PM me with what you need.
    Dave Fox
  2. bigfitz52
    Don't take them too far apart. Keep the cams and caps with the heads, etc; main bearings/crank/crankcase need to stay together.
    What "style" are the valve covers? Both black with the letters machined, or is one of them a "nekkid" cover?
    I didn't see your listing for the whole motors, any idea of mileage on either?
  3. hogfiddles
    Hey Fitz..... just sent you a pm.
    Dave F
  4. RudieDelRude
    RudieDelRude Member
    Illinois (STL area)
    Will they bolt into an 82 Seca? How much were you wanting for a whole motor? That is if its still in one peice
  5. hogfiddles
    My understanding is that the 550 engines are different from the maxim to the seca.
    Dave
  6. moellear
    moellear Member
    Lima, Ohio
    would a carb rack for 550's be interchangeable? brain went dead at this time of night and can't think. i should really get to bed
  7. hogfiddles
    I believe they're different, too.........could be wrong on that, but don't think so.
    Dave F
  8. warchol2
    warchol2 Member
    st.clair MI
    carb intake rubbers?
  9. hogfiddles
    airbox to carb or carb to head?
    dave
  10. warchol2
    warchol2 Member
    st.clair MI
    o sorry carb to head
    and also im under the impression they will fit my 81 maxim 650 but i dont think they will
  11. hogfiddles
    nope, these have a good amount of cracks, don't know if they go all the way through, though ,or not......haven't checked that.
    Dave
  12. zombiehouse
    zombiehouse Member
    Pomona, Ca
    The 550 Maxim motor will fit the 550 Seca. The difference is in the cams. All hookups are the same. The carbs are also the same with different jetting.
  13. bigfitz52
    There are subtle gearbox differences; one or two slightly different gear ratios (IIRC) as well.
    Otherwise, except for the differences mentioned above, the motors are mechanically the same.
