change handle bars problems
Discussion in 'XJ Technical Chat' started by alexleon809, Mar 14, 2012.
  1. alexleon809
    alexleon809 New Member
    durham nc
    guys thx in advance for your advice , recently i changed my stock handle bars for clubman style handle bars of my yamaha sr550r , everything was fine throttle cable , clutch cable , break cable the only thing that I had to remove was the instruments panel and put it together again after move the cables for behind , tie every bolt again but when I stared the bike I noticed , that my head light the instruments lights and the left turn signal it is not working the right side it is ok and the tail light it is working fine any ideas , and can anybody tell me where can I find the fuse for this lights maybe a fuse it is blow I do not why but who knows ??
    chees
    Alejandro
  2. MiGhost
    MiGhost Well-Known Member
    Double check all your electrical connections buried in the headlight housing. It is very possible that you might have pulled the connectors loose when working with the gauges.
    Ghost
  3. alexleon809
    durham nc
    thx I will check it tomorrow and I will let you know
    cheers
  4. mlew
    Nice to have another member in the RDU area.
  5. alexleon809
    durham nc
    thx , are going to the euro bike show ? may be we can ride together
    cheers
