Power Point
Discussion in 'Hangout Lounge' started by RSpark, Feb 5, 2012.
  1. RSpark
    RSpark Member
    Dubuque, IA 52001
    Has anyone here ever attached a cigarette lighter powerpoint to your XJ's? I am thinking of hooking one up but was wondering where to place it.
  2. Polock
    you want the 12V socket or a plugin usb adapter ? my adapter sets on top of the air box, hard wired to the fuse block
  3. RSpark
    RSpark Member
    Dubuque, IA 52001
    The 12 volt socket would be prefferable. Do you have pics of yours?
  4. iwingameover
    iwingameover Active Member
    Got mine mounted to a small fairing above the gauges. Wired into switched 12v in the headlight bucket. Phone/gps goes in a handlebar mount.
  5. Polock
    this was temporary 2 or 3 years ago
  6. RSpark
    RSpark Member
    Dubuque, IA 52001
    Very nice Polock
  7. mlew
    Put mine under the gas tank, Its bolted to the back of the horn bracket.
    Powered by a auxilary fuse in the fuse box.
  8. RSpark
    RSpark Member
    Dubuque, IA 52001
    Thats actually a pretty nice location mlew
  9. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I just have an automotive type cigarette lighter mounted on my handlebars. Mine's actually for lighting my cigarettes, but I also use it to power my GPS when I take longer trips.
    Here's how I mounted it. I used a piece of aluminum for my grip heater switch and cigarette lighter (yes, my cockpit is a bit cluttered) There's also a mount for my Sony Walkman radio and MP3 player and the cord that plugs into them that goes to the amplifier to power those speakers on the backside of the windshield.
  10. mlew
    It is out of the way and out of the direct weather. I have found you DON'T want to mount them pointing up, it will collect water and rust. I primarly use it for a GPS, its handy and not noticed.
  11. Oldyoungster
    Oldyoungster Member
    Queens, NY
    I started on this project and was wondering what size fuse you guys are using. Is 10a okay?
  12. iwingameover
    What are you running off of it?
    A phone or GPS that normally charges with a USB port is in the milliamp range. USB 2.0 is 500mA.
  13. RSpark
    RSpark Member
    Dubuque, IA 52001
    Can i hook up a usb port to the bike then?
  14. iwingameover
  15. RSpark
    RSpark Member
    Dubuque, IA 52001
    Now I am wondering though if instead of a cig lighter I could just use a usb port off a computer.I use the usb port to charge my phone anyway and something that small would be much easier to mount
  16. iwingameover
    You would first have to bring the bike's voltage down to the 5V that the USB needs. That's what that adapeter or your lighter charger for the phone does.
  17. RSpark
    RSpark Member
    Dubuque, IA 52001
    I gotcha, right now I am gathering the materials needed to switch my turn signals and running lights to LEDs which should bring my voltage down plenty.... well at least in theory anyway. that should buy me enough voltage to play with.
  18. iwingameover
    Voltage is constant or nearly constant.
    Running at cruising RPM you're going to be +/- 14V depending on your charging circuits current shape.
    Amperage is what gets reduced by going to the LED's.
    To use a straight USB port on the bike you would need a voltage regulator to get you 5V a the USB. The lighter adapters already have that regulator built in.
  19. RSpark
    RSpark Member
    Dubuque, IA 52001
    I gotcha that makes sense I guess I'll stick with my power point then. Thanks for the heads up iwin
  20. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    I have a fused lead from my battery that I use for my solar battery charger. I also use it as my connection for my electric vest. I bought a marine 12 volt power point and wired on a plug in that hooks to the same lead. I have used it to power an air compressor I carry with me. I also bought a USB adapter that plugs into the power point but have yet to use it. Should work though.
  21. NS_Rider
    NS_Rider Member
  22. DuoDS
    DuoDS Member
    South Jordan, UT
    I have seen guys take apart one of those USB car adapters (carefully) and hook the 12v side of it up to a fuse and then the battery (out of the way) and run wires to where they want the USB plugs. So when they are done, the only thing you can see is a couple of working USB plugs peeking out of a plastic fairing or something.
    Seen guys do the same thing with a garage door opener, Find one - take it apart, and mount the main parts on the bike where they are out of the way, run wires to the button/switch mounted to their bars or something, so they can hit the button at will.
  23. skoster
    skoster Member
    Edgewater, Maryland
    That's what I did.
  24. darkfibre
    darkfibre Member
    Perth, Australia
    I have a C-tek charger socket connected to the battery, and made a lead to adapt the usb 5v socket to it. Works well.
    Once you have a power socket, you can make other things too:
  25. gunnabuild1
    gunnabuild1 Member
    Is that a slime pump with the casing removed?
