update on the 3D project for 3/26/2012
Discussion in 'XJ Technical Chat' started by FlyGp, Mar 4, 2012.
  1. FlyGp
    FlyGp Member
    Michigan
    Just another update on the 3D project, this week I began work on the transmission, the parts in this test render are not in the correct locations but this will give you the idea.
    As usual I would appreciate any comments and suggestions.
    FlyGp
  2. hogfiddles
    Re: Just another update on the 3D project for 3/4/2012
    nice
  3. lostboy2
    lostboy2 Member
    Crimora, Va
    Awesome work as usual Fly. Keep up the good work. I still would like to see a CD of all this stuff!
  4. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Yeah I can't wait for the CD either
  5. FlyGp
    FlyGp Member
    Michigan
    I managed to make some progress on the gearbox modeling. The middle gear anti-shock drive is now complete along with the shift forks and selector drum.
    Will be modeling the starting sprag clutch next, the parts look relatively simple so it should go smoothly.
    Motor internals are approximately 80% complete; the biggest challenge in the near future will be the engine castings. Castings are my nemesis because of the difficulty accurately measuring the details as some of the shapes look almost hand carved.
    This is the latest test rendering, if you see any errors feel free to let me know, your input is always welcome and truly appreciated.
    Thanks FlyGp
  6. UranuX
    UranuX New Member
    That's amazing. Keep up the good work!
  7. uhoh
    uhoh Member
    BC, Canada
    Wow -- would love to have this large enough for a background image with a stylized Design by FlyGP logo in the corner! Amazing stuff!
  8. FlyGp
    FlyGp Member
    Michigan
    I had a productive weekend working on the starter clutch model. The clutch is quite the clever device.
    Now that this has undergone the modeling process I can see why using oil with friction modifiers would cause this device to slip.
    FlyGp
  9. Polock
    do you have motorcycle parts, like all over your house? :)
  10. Massimo33
    Massimo33 Member
    Denver, CO
    Amazing, these renderings are absolutely incredible, as are all the previous ones.
    I can't wait to be able to see it all together on one disc.
    Awesome job,
    Massimo
  11. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    Did Yamaha really use all those "Pastel" colours when they built this stuff? :roll:
    Just kidding, Fly, you are "Fly"! 8)
