'80-'81 xj650 PARTS (Signals/covers/relays)
Discussion in 'For Sale, Trade/Swap, Wanted' started by 750MaximSeattle, Mar 19, 2012.
  1. 750MaximSeattle
    750MaximSeattle Active Member
    Seattle, WA
    For photos see: http://seattle.craigslist.org/sno/mcy/3623117878.html
    NOTE: if you previously viewed that link, refresh your browser for updated photos and text.
    Parts from (2) xj650's, 1st list of 1980 and 2nd list of 1981 Maxim parts...
    1) ....from a 1980 xj650 Maxim with under 23k miles. No frame, forks nor wheels:
    Oil Pan w/drain plug - $15
    Throttle cable - $10
    Throttle tube w/grip - $10
    LH exhaust bracket - $5
    RH exhaust bracket w/foot peg- $10
    Rear brake lever - $15
    Tail Light assembly (excellent condition!) - $25
    Rear signals w/mounts - $25/pair
    Front signals (just chrome & lens) - $20/pair
    Front brake rotor - $10
    Relays - $5
    - These parts were SOLD:
    Wiring harness - $10 (SOLD)
    Rectifier (regulator) - $20 (SOLD)
    Oil filter cover - $15 (SOLD)
    Clutch cover - $15 (SOLD)
    Tranny cover - $10 (SOLD)
    LH Controls (signals/horn/highbeam/choke) - $10 (SOLD)
    Ignition Timing Pick up coil - $20 (SOLD)
    Stator - $15 (SOLD)
    Stator cover - $10 (SOLD)
    RH Crankcase cover - $5 (SOLD)
    LH Crankcase cover - $10 (SOLD)
    Rear Fender - $20 (GONE)
    CDI (igniter) - $30 (SOLD)
    Guage cluster - Tach & ODO (22,540 mi.) - $30 (SOLD)
    Head Light assembly - $40 (SOLD)
    22,540 mi. engine with good compression - $50 (SOLD)
    4-1 exhaust system (including headers) - $30 (SOLD)
    Ignition (new) - $15 (SOLD)
    Ignition (used) - $10
    Tach cable - $15 (SOLD)
    Carburetor - $50 (SOLD)
    Starter motor - $50 (SOLD)
    Tank (minus petcock) - $20 (SOLD)
    Petcock - $15 (SOLD)
    Seat - $20 (SOLD)
    Side covers - $20 each (Both SOLD)
    Foot pegs (set of 2) - $20 (SOLD)
    2) ....parts from a 1981 Maxim:
    Chrome air box cover $5
    Rear brake lever - $10
    Tail light - $20
    Chrome airbox covers with '650' emblems -- $15/pair
    Rear signals with mounts - $25/pair
    Side reflector that bolts to frame near the forks - $5
    Relays $5
    These parts are SOLD:
    (Flat) headlight $25 (SOLD)
    Shocks -$10/pair (SOLD)
    (standard) Headlight FREE (GONE)
    Handlebars w/grips $5 (SOLD)
    Mirrors - $10 pair (SOLD)
    Foot pegs - $10 pair (SOLD)
    Rectifier - $20 (SOLD)
    CDI (Igniter) - $30 (SOLD)
    Final drive - $30 (SOLD)
    Ignition switch/handle bar cover - $10 (SOLD)
    Petcock - $20 (SOLD)
    Starter - $40 (SOLD)
    Carbs - $40 (SOLD)
    Headlight assembly - $25 (SOLD)
    Gauge cluster (ODO 15,000 miles) - $35 (SOLD)
    (plastic) side covers with 'MAXIM' emblem - $40/pair (SOLD)
  2. hogfiddles
    Re: xj650 parts (carbs/starter/side covers/gauges/signals...)
    Hey 750,
    I'd like dibs on the pair of side covers, the headlight assembly, and the guages.
    Please PM me, and I'll get a money order together.
    Dave Fox
  3. moellear
    moellear Member
    Lima, Ohio
    dibs on the carbs... email sent
  4. 750MaximSeattle
    Seattle, WA
  5. 750MaximSeattle
    Seattle, WA
    Pleasure doing business with you!
  6. zippy941
    zippy941 New Member
    Re: xj650 parts (petcock/covers/signals/reflector)
    would you take 13 for the petcock? Is it in good usable condition? Mine has 40k miles & leaks.
  7. 750MaximSeattle
    Seattle, WA
    SOLD. Pleasure doing business with you.
  8. 750MaximSeattle
    Seattle, WA
  9. XJ650nOOb
    XJ650nOOb New Member
    Missouri
    Wiring harness is that he whole harness? If yes I'll take it.
  10. 750MaximSeattle
    Seattle, WA
    Sorry, I sold that a week ago...ad is now updated.
  11. 750MaximSeattle
    Seattle, WA
