My 1983 Xj 750...... student budget bike.
Discussion in 'XJ Modifications' started by JACK-BRAP-113, Dec 12, 2011.
  1. JACK-BRAP-113
    JACK-BRAP-113 Member
    deadmonton Alberta
    Soooo after watching Kijiji like a hawk, i ended up picking up this Xj for 300 bones.
    Pumped!
    first stop. Car wash. bike had been kept for 2 years in a shed with no door.... soooo needless to say it needed a bath.
    the story is... the PO had bought it to bomb around town on, scared him self and parked it. he had bought it from a motorcycle mechanic who had changed out the fuse panel and some other regular maintenance from what i can see.
    the kickstand switch was sooo bunged up i just removed the whole assembly. and had to lose those awful bars!!!
    next was that seat! had to go!!! along with the rest of that god-ee frame!
    sooo we got the moto bars mounted and chopped frame!
    i then checked valves and replaced the valve cover gasket and rubber as it was leaking!
    seat time! street sign
    this is where i am now!
    let the critics at it! im new to this sooo feel free to give me some tips and tricks and even tell me out right if im not doin it right.
    also picked up a white wall for that rear! and cleaned up the exhaust!
  2. JACK-BRAP-113
    deadmonton Alberta
    Re: My 1982 Xj 750...... student budget bike.
  3. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    Howdy from Las Vegas, I think you have an 83 not an 82. The 82 has a rectangular head light, and much different instruments. Of cource, I may be wrong as the PO could have changed all this. Is that what it is? Then again, it may be it's a canuck model.
  4. JACK-BRAP-113
    deadmonton Alberta
    sorry yes... 83... to many bikes in my mind
  5. LVSteve2011
    LVSteve2011 Member
    Las Vegas NV
    AH HA! I knew it! A good way to tell, if you have no V.I.N. sticker that is, is to look under the tank to see if you have a disconnected fuel sending unit wire. The 83 has no gas gauge.
  6. bigfitz52
    All XJs have their "shorty" VIN cast into the top of the transmission housing; that's all you need for a positive ID.
  7. mtnbikecrazy55
    What is that outer plate in the end? as it already there?
    Mine - also an 83 750 does not have that andi think it looks nice...
  8. mtnbikecrazy55
  9. Mmswole42
    Mmswole42 New Member
    How did you mount those bars??? Im looking to put a set of clubman bars on my 82, need to find mounts.
  10. Mmswole42
  11. RickCoMatic
    If you are doing-away with the Vinyl-wrapped part pf the Sissy-bar; I'll be happy to give it a new home.
    I'd like to have Handlebars on my 750-Max like those, too.
    What Brand Name are they?
    The seat has a look of being too "Light-weight" in the photos.
    The Springs don''t seem to look "Heavy-weight" enough to be comfortable, supportive, and remain positioned very well.
    Having that Cross-member so strategically located for a stability and anchor-point, ... you could integrate Composite Elastomers or adapt a Shock-absorbing Seat Post.
    Shock-absorbing Seat Post:
    http://www.thudbuster.com/products.html
    Elastomers:
    http://www.rmhcontrols.com/tecspak.html
  12. zap2504
    zap2504 Member
    Middletown, PA
    You might also want to reconsider re-mounting the front fender as the OEM fender has a built-in fork brace underneath. Or cutting back the fender to the brace, but no front fender will mean lots of road grunge fling.
  13. JACK-BRAP-113
    deadmonton Alberta
    sorry for the late response, i have been busy though...
    1st- the bars are just sunline motocross bars- the cross bracing, you could do to bar adaptor for any motocross style fat bar if you where worried about the missing brace..
    2nd- yes i know......:( the seat sucks..... i took it for a ride in the snow the other day and just couldnt get it to feel safe-ish.... sooo its scrapped.... but good news it i got a new one... and some pictures....
  14. JACK-BRAP-113
    deadmonton Alberta
    ok new seat
  15. JACK-BRAP-113
    deadmonton Alberta
  16. JACK-BRAP-113
    deadmonton Alberta
  17. JACK-BRAP-113
    deadmonton Alberta
  18. JACK-BRAP-113
    deadmonton Alberta
  19. JACK-BRAP-113
    deadmonton Alberta
  20. JACK-BRAP-113
    deadmonton Alberta
  21. Polock
    what da heck is that green stuff in the bowl on the chair ?
  22. JACK-BRAP-113
    deadmonton Alberta
    SPINACH!!!!! mmmmmmmm
  23. streetbrawler750
    streetbrawler750 Member
    Minnesota
    fer yer muss culls, agh agh agh agh- toot toot
  24. RickCoMatic
    I noticed Forward-facing Lights with Red Lenses.
    That would get you in serious trouble, here, in Massachusetts.
  25. mtnbikecrazy55
    X2 on the forward facing red lights. either white or amber, or you're going to get pulled over.....eventually...lol
  26. JACK-BRAP-113
    deadmonton Alberta
    in alberta apparently its allowed.
  27. JACK-BRAP-113
    deadmonton Alberta
    It has been awhile but. did some more work to get this thing on the road...
    Home made sign plate holder with reflective feature! and the new tail light...
    still need to cover the seat, figure out how to hide everything under the seat... thinking plastic molded over the frame and down into the side covers...
    but as it stands... we are ready to ride!
  28. XJLee
    XJLee Member
    Vancouver
    You've inspired me to get back to work on mine!
    What are you planning on doing with the rear of the frame?
    Leave it open? ...cool.
  29. xjjammer
    xjjammer New Member
    binghamton NY
    do u know where i can get low bars that will fit a 1982 yamaha
  30. JACK-BRAP-113
    deadmonton Alberta
    i used motocross bars
