Final drive leaks from breather
Discussion in 'Hangout Lounge' started by fakeplay, Apr 19, 2012.
  1. fakeplay
    fakeplay Member
    Newburyport, MA
    Hi, My final drive leaks a little oil. I geuss from the breather. The very top of the drive with a little cap type thing on it. I don't want to break the cap if it isn't removable but how can I fix this small leak. Thanks
  2. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    Well it is what it is, a breather. It's doing its' job of breathing.
    Try to syphon a bit out of the final drive box or drain it. Or if you can't syphon any, just get a dry rag and put it in the filler and let capilary action extract a bit of excess transmission fluid.
    That's what i'd do.
  3. wwj750
    wwj750 Member
    central minnesota
    Mine does this too sometimes & always wondered why. I drain the old stuff & refill with new. Seems to help. Quick & easy enough to do & sure doesnt take very much oil. I use SAE 80/90 hypoid gear oil as per my manual. I wonder if there is something better to use that would prevent this.
  4. boostenlebaron
    boostenlebaron Member
    Sturbridge MA.
    Ive found mine does it when its cold out but once it or the weather warms up im fine.
  5. fakeplay
    fakeplay Member
    Newburyport, MA
    I wish there was a level window on these things. Thanks
  6. FJ111200
    I've lost count of how many shaft drive bikes i've owned, but if they are filled with the correct amount of oil they don't leak.
    Check the manual for the correct amount.
  7. fakeplay
    fakeplay Member
    Newburyport, MA
    It say right up to the plug nut level. That what I did. I think
  8. FJ111200
    On level ground, just below or just up to the threads of the filler?
    To be honest with you, i'd ignore that and go with the recommended amount in the manual.
  9. wwj750
    wwj750 Member
    central minnesota
    Thats right. On the centerstand, fill up to the edge of the filler hole. Almost impossible to overfill.
  10. fakeplay
    fakeplay Member
    Newburyport, MA
    Is what I did.
  11. mlew
    Check you manual for proper oil fill. Sometimes filling to the threads on the fill hole is too much, that will cause oil too weep out the vent. On the XJ and XS 1100 the proper fill is about an inch BELOW the fill plug.
  12. RickCoMatic
    When the azz-end leaks from the Breather, ...
    It means the Breather's working OK.
    Cooled Hypoid likes to ooze-out of there.
    It happens alot.
    If you can find a Racing Blend (80W/140) ... i t doubles as "All Season"
    Correct Filling helps.
    Level surface.
    Center Stand.
    Empty Drive Unit.
    Fill s-l-o-w-l-y.
    The BOOK shows the Level of Gear Oil at the TOP Thread, ... just about starting to spill-out.
