VIN Number Issue.
Discussion in 'Hangout Lounge' started by Bleaches, Apr 19, 2012.
  1. Bleaches
    Bleaches Member
    Calgary, Alberta
    Hi all !
    Crazy thing, bought an '82 Maxim, previous owner had it registered, I went to change the ownership today and they said there is a problem with the VIN number because it is only 10 digits and should be 17 8O . Can anyone confirm this. Both numbers on my bike match the 10 digits on the original registration. When I asked how it was possible that someone else registered with 10 digits she said they had made a mistake (scratching my head) ..
    Thanks in advance,
  2. TIMEtoRIDE
    Do you have a white tag - or is it missing??
    You can "generate" a 17 digit VIN # using Chacal's guide, in "information overload" , but printing a white tag can be tricky.
    Do you really need the white tag in Canada??
    Will they accept your "new" VIN# and how would they check??
  3. mlew
    Entirely possible.
    Bikes made before 1981 or 1982 had 10 digit VIN #s. Your bike was made before then and titled in 1982. I had the same issue with my XS1100. I had to bring a photo of the VIN to the DMV to prove it. No problem after that.
  4. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    There were plenty of bikes before the law took effect that were titled with a 10 digit. Chacal's VIN page will get you your 17 digit VIN. If you can't get it figured, post the 10 digit and we'll help you out. All you are missing is the 3 letters, two numbers, and the check digit, which is the hardest part of figuring the VIN.
  5. bigfitz52
    There sure were. My 1974 Norton has a SIX digit VIN.
    (Drives the Michigan Secretary of State folks crazy.)
  6. tskaz
    tskaz Active Member
    Score one for the little guys :lol: :lol: :lol:
  7. Bleaches
    Bleaches Member
    Calgary, Alberta
    Thanks so much guys, I had the revalation a couple hours ago about the 81 made 82 title, I'll let you know how everything works out tomorrow when I goto the registry,
    thanks so much
    Mike ~
