Rear wheel locked up
Discussion in 'Hangout Lounge' started by Uberstranger, Apr 20, 2012.
  1. Uberstranger
    Uberstranger New Member
    Middlesex NJ
    I'm looking for some help. I bought a '83 XJ750K recently. It didn't run on account of an electrical issue. Fixed that and she fires, not quite runs but still.
    The issue now is that the rear wheel seems locked up, if I push start it, it will start the engine, so I feel I can rule out broken driveshaft, but it's very resistive, to the point where the tire skids for a few seconds before rotating.
    I've checked the final drive fluid, OK. Can you think of any tests or checks I should try before I take the drive shaft apart?
  2. mwhite74
    mwhite74 Member
    Did you check your drum? More specifically your brake pad? That's #1 on your list of things as a new XJ owner...
  3. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    Your rear brakes may have delaminated. Don't try to ride it until you have checked/replaced them!!!
    Rear brake pads are in expensive.
  4. Uberstranger
    Middlesex NJ
    Sorry, I left out that it rolls in neutral
  5. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    Those few seconds, are you sure they are'nt half seconds?
    It sounds like normal push or drag on the clutch to me.
    Are you a big bloke? Maybe a big bloke could push a bike in gear and make the rear tyre skid. :lol:
  6. Metal_Bob
    Bourbonnais, IL
    Still sounds like stuck and dragging rear break.
    Even if its not check it to potentially save your life. Takes 10 min and a new cotter pin if bolts not seized.
  7. hogfiddles
    If it rolls EASILY in neutral, that would temporarily rule out bad shoes. If it does roll easily in neutral but not when in gear, that would suggest seizure issues somewhere from the the clutch to the final gear. If the rear wheel is rolling easily, it would discount the rear drive through the U-Joint into the final gear, as that will all turn as a unit with the rear wheel. So, I'd think somewhere in the trans. area.
    Dave F
  8. Polock
    the clutch might need adjusted
