XJ550RJ 82 - replaced fuse box - rusting build up ?
Discussion in 'XJ Technical Chat' started by yamamann, Apr 25, 2012.
  1. yamamann
    yamamann Member
    Barrie, Ontario, C A N A D A
    Replaced last year - everything good BUT noticed a build up of non-conductive material on each fuse - will cutting off the oxygen by covering each contact area ( only around each contact ) with something like white grease help prevent the problem ? I know I should have used a newer blade style fuse box but the job is done - thanks
  2. Wirehairs
    Wirehairs Member
    St. Paul, MN
    I'd suggest a dry film lubricant - there are a variety OK for electrical connections. That should help protect and help with your corrosion problem.
  3. yamamann
    yamamann Member
    thanks will follow your suggestion - has anyone else had this problem ? I'm almost thinking that the reaction takes place between the plated end caps on the glass fuse ends and the plated tabs or saddles they snap into - bike has not been wet since the replacement - weird
  4. RickCoMatic
    You can get a Product called: Contact Re-Nu
    A spray-on Electrical Solvent that Cleans, and De-Oxidizes all Contacts and Switches.
    The Product is safe for Auto-MC Electrical Components and Computer connections.
    Evaporates and disappears shortly after use.
  5. yamamann
    yamamann Member
    Update - Bluemagic brand brush-on electrical tape 4oz can did the trick - problem solved just brush on exposed metal contact points and rusting or chemical reaction stopped - can replace fuses as needed and re-apply
