wiring from scratch
Discussion in 'XJ Technical Chat' started by timbojim, May 17, 2012.
  1. timbojim
    timbojim Member
    Kelowna, BC, Canada
    I have made a few posts, asking about wiring. When I went to wire all of my components together, I had some difficulty with making all the right connections. This needs to be done soon, and we are running out of time, so I ask you; how should I go about making my wiring harness from scratch?
    I am using this wiring diagram:
  2. maverickbr77
    maverickbr77 Member
    Lowville, New York
    I don't understand where the issue is. You have the diagram, find the correct starting point and run the wires one section at a time to make sure you run all the one you need to the right places.
    If you are having trouble with getting a specific component to work or finding a wire from a component we can probably help but you will need to be more specific.
    Ps. I am just about to make a harness using this as my base as well
  3. Groundswell17
    Groundswell17 Member
    Maryland, US
    i did one using this, and what i just did, wired the starter and all that first, then ignition, then lights and all that jazz. I just went at it, trying to group new wires as i went. you'de be hard pressed to sit down, measure everything out, cut it, tape it all up, and just pop it in and be done.
  4. timbojim
    timbojim Member
    Kelowna, BC, Canada
    any tricks you used? any special advice?
  5. Orange-n-Black
    Memphis Area
    what about turn signals. Its illegal in most places to operate a motor vehicle without them. Most people omit them with the minimal wiring, but I would rather other people know if I'm turning. It's hard enough to get others to see you as it is.
  6. maverickbr77
    maverickbr77 Member
    Lowville, New York
    not that hard to add them in power to flasher to switch to lights to ground. I also have a horn, neutral light, and aux outlet drawn into my diagram.
    Or leave them off and only wire up want you want to/need to for what you want.
  7. Orange-n-Black
    Memphis Area
    I was just going by the diagram. Unless the harness is bad and needs to be replaced, I would just omit what you don't want. That would be less work as long as you have the proper diagram.
  8. Orange-n-Black
    Memphis Area
    Hey I'm a Wizard now! It has to be a trip...... sorry wrong wizard.
  9. adrian1
    adrian1 Active Member
  10. maverickbr77
    maverickbr77 Member
    Lowville, New York
    @Adrian of course you can pick one up on ebay or even here in the forums but its still 30 year old wire and connectors that you would need to go through, clean up, and hope there are no major issues. Build your own you know its all new.
  11. adrian1
    Yeah I get that but he said he's in a hurry and was having problems
  12. maverickbr77
    maverickbr77 Member
    Lowville, New York
  13. KH666
    KH666 New Member
    West Yorkshire , England
    Hi, thought I'd jump on this thread with my question as it's basically the same.
    If this is ok with Timbojim?
    I'm looking to do my own loom as well for my 81 maxim and am wanting to know the thickness and amp of wires for lights, ignition, start switch etc and for the higher amps, i.e, starter motor, coils, etc.
    Just starting out so forgive the question if it should be obvious :?
  14. maverickbr77
    maverickbr77 Member
    Lowville, New York
  15. detroitdiy
    detroitdiy New Member
    ferndale mi
    pay someone else to do it!
    just kidding, take your time...you cant really rush building a safe wiring harness if you dont want any loose connections or shorts, the minimum diagram works but youre on your own as far as wire length
    btw, turn signals are harder to see than arms in my opinion and arms never burn or short out, im not saying dont use them but if you dont (as long as your legal) its all good
  16. KH666
    KH666 New Member
  17. maverickbr77
    maverickbr77 Member
    Lowville, New York
    your stock flasher/self cancel wont work with them. you can get them to work with a new electronic flasher and can get the self cancel to work by adding in a relay there is a write up here with how to do it.
  18. maverickbr77
    maverickbr77 Member
    Lowville, New York
    also your forks are 36mm so those wont fit without at least adding some kind of shim
  19. KH666
    KH666 New Member
    Hmmm ok thanks for that, I'll be looking for something else I think.
    So a stock flasher/cancel unit will work with any arm indicators?
  20. maverickbr77
    maverickbr77 Member
    Lowville, New York
    the bulbs need to draw enough current to run it which is darn near what the stock bulb draw, or you can add resistors to make up the difference, if you want to keep the stock flasher/canceler.
  21. KH666
    KH666 New Member
    Hmmmm read the wire chart, my brain is fried trying to figure it out, any chance of an idea?
    Tell me if I'm wrong but for the lights/starter button/speedo/tacho, 20 amp/16 gauge wire would be sufficient?
    And for the higher/hotter Amps, I'm thinking 60 amp/12 gauge for the starter motor/ignition/coils?
    If not and I'm wrong, prod in the right direction if possible :)
  22. darkfibre
    darkfibre Member
    Perth, Australia
    Just copy the original wiring sizes, can't go wrong.
  23. KH666
    KH666 New Member
    I did a classic Homer, D'oh, will realise something when it's been staring me in the face.
    Thanks darkfibre.........
