Maxim x... Is this normal???
Discussion in 'XJ Technical Chat' started by ryancdossey, May 20, 2012.
  1. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    So I was working on the bike today and noticed two things.. Screw holes with no screws in them??
    these are on both sides of the engine? I didnt remove anything from them and it ran fine before the slide... SO I am assuming that it is fine?
    This one is on the left side looking at the bike head on. I was doing a coolant system flush and noticed one of them didn't have a screw in it? But it looks to be the same in the coolant flush pdf that was posted on here.
  2. tumbleweed_biff
    tumbleweed_biff Active Member
    Gahanna Ohio
    Can you mark the pictures some how to show this? I am not seeing any missing screws ...
  3. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    On the top picture it is what looks like the white circle.
    On the bottom one it is to the left of the new silver screw
    Does that help?
  4. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Dang I suck at using paint...
  5. KatherineJaneIII
    KatherineJaneIII New Member
    Anderson, MO
    Just checked my Maxim X and found the exact same thing - screw holes with nothing in them. I've had absolutely NO problems with mine at all ! ! So... No worries !! I believe it is perfectly normal.
  6. smurf667
    smurf667 Member
    Newark, Nottinghamshire, England
    Can you point me to the pdf you mentioned please, I've not seen that.
  7. schmuckaholic
    California
    Try this.
    I should go back and tweak that a bit -- perhaps mention that filling the coolant tank before restarting the engine would be a good thing. Still, HAP seemed happy enough with it.
  8. patmac6075
    patmac6075 Active Member
    MKE
    Perhaps those with more knowledge can correct me, but I think you find these extra screw holes because these engines were places in multiple configurations. Although, those screw holes may serve no purpose on your bike, perhaps it may have been there to fasten something on a Euro model...or maybe an earlier model?
    Just guessing, but it make sense to me.
  9. tumbleweed_biff
    Gahanna Ohio
    Or the engineer thought something was going to go there and it turned out otherwise. Die already made? Use it, but don't use the holes. Far more efficient that halting production, remaking the dies, and starting over. For all of us out here in the real world,. it becomes one of those "Undocumented User Entertainment Features," a phrase I coined back in the mid-90's regarding software defects.
  10. Maxim-X
    Maxim-X Well-Known Member
    London Ontario Canada
    It's just the Asian design engineers having a laugh at our expense.
    I can just see it now.....
    1st engineer:
    "Ret's put sclew holes in brock and not attaching anything to them".
    2nd engineer:
    "Dat's leery funny, should mess up heads of Nolth Amelican Maxim-X liders"!
    "Ho-hoho, ha-haha, Dang Dong, you ah a funny guy"!
  11. Darth_Menace
    Darth_Menace Member
    Alberta
    man, that was hilarious. good to find another Canadian on this site
  12. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    There's supposed to be a cap there... it's your blinker fluid resivior....
  13. tradmedic
    tradmedic Member
    BWA HAH HAH. Good answer!
