oh for forks sake.......
Discussion in 'XJ Technical Chat' started by oz_johnno, May 24, 2012.
  1. oz_johnno
    oz_johnno New Member
    Howdi blokes,
    currently trying t pull the front forks off my 81 xj550 seca and the manual isnt being much help.
    I have loosend the pinch bolts at the top of the fork leg but the forks still wont rotate.
    what is the best way to proceed.....
    (sorry if this is a stupid question but this is the first time I have ever pulled apart a bike for renovation)
    Cheers
    OZ
  2. maverickbr77
    maverickbr77 Member
    Lowville, New York
    what bike are you working on? did you loosen the one at the very top and the two down by the Yamaha emblem on each side?
  3. Bushy
    Bushy Active Member
  4. oz_johnno
    thanks bushy, armed with this new information, I shall boldly sally forth....
    OZ
  5. bigfitz52
    -Remove the fender if you haven't already. (The integral fork brace can put a bind on the forks.)
    -Loosen the two pinch bolts at the top.
    -Loosen the two pinch bolts on the lower triple tree (hidden by the trim piece.)
    They'll slide out. It's even easier if you also remove the front wheel.
