Need new tires/ Can't find size!!! Help?
Discussion in 'XJ Technical Chat' started by XJrider302, Jun 1, 2012.
  1. XJrider302
    XJrider302 New Member
    Delaware
    I'm looking for tires for my 82 yam 550 maxin and I just can't find tires that match each other that has the right front tire size. Can anybody help?
  2. Omega650
    Omega650 New Member
    Tulsa, OK
    Just buy two different brands.
    I have Bridgestone on the front and a Pirelli on the back.
  3. XJrider302
    Delaware
    Thanks. I really didn't want it to come down to that but it looks like I have no choice.
  4. mlew
  5. XJrider302
    Delaware
    I've read a few different things that say different sizes but they size I've seen the most was 3.25-19 Front and 110/90-18 Rear
  6. mlew
    What size is on you bike now?
    The parts book calls for a 130/90-19 rear and a 325h19 front and I think that is the same as a 100/90-19.
    Should not be hard to find two tires of the same brand. Not to say you cant do it but I like my tires to match.
  7. XJrider302
    Delaware
    Im not sure of the actual size that is on there now but I guess it would be to hard to find out. Which parts book did you get that info from? And since it was a restoration project I really want the tires to match
  8. mlew
    Any online Yamaha parts lookup website has the same things. I like BikeBandit.com their layout is easy to navigate.
  9. XJrider302
    Delaware
    Thanks, I'll take a look at it.
  10. greg_in_london
    greg_in_london Member
    London
    From memory,
    90/90H19 - 3.25H19 (or 3.60)
    100/90H19 - 3.50H19 (or 4.10)
    110/90H19 - 4.00H19
  11. bigfitz52
    Those are the original tire sizes for the 550 Seca. The factory book has a typo listing the rear wheel size on the Maxim incorrectly, and it's been carried over a lot.
    Your Maxim has a 16" rear wheel, not an 18.
    On the front, you can run a 90/90-19 or a 100/90-19; the 90 is closer to the original size, the 100 fills the fender better and gives you a tad more meat on the road.
    On the rear, you want a 130/90-16.
    This is a good recommendation:
  12. fr00t_mulp
    fr00t_mulp New Member
    Fort Collins, CO
    I know this is an old topic, but Fitz, won't using a 100/90 instead of a 90/90 tire give false speedo readings? Or is it negligible?
  13. mtnbikecrazy55
    No, circumference will be the same, just wider contact patch.
  14. bigfitz52
    If you find a Yamaha mechanical speedometer that's accurate enough to tell the difference be sure to share.
  15. Kickaha
    New Zealand
    The circumference won't be the same, the 100/90 will be slighly bigger But like Fitz said
  16. tskaz
    tskaz Active Member
    Saint Louis, Michigan
    Just to explain tire size:
    mm/X%-rim diameter
    100/90-19
    100mm wide, 90mm (90% of width) tall, 19 inch rim
    90/90-19
    90mm wide, 81mm (90% of width) tall, 19 inch rim
    It will have a 9mm larger diameter. Should equal out to around .75mph slower. About half the width of the needle.
  17. bigfitz52
    Like I said;
    And I think you meant 19-inch rim, Kaz.
  18. OldBikerDude
    OldBikerDude Member
    Hood River, OR
    On my 82 XJ550 I run Metzeler ME 880 Marathons on both front and rear. If your wheels are stock then you want 100/90-19 for the front and 130/90-16 on the rear. These are great tires. Love them! These are easy to find also...
  19. tskaz
    tskaz Active Member
    Oops, I did. Fixed.
