XJ engine angle?
Discussion in 'Hangout Lounge' started by 0versteer, Jun 7, 2012.
  1. 0versteer
    0versteer New Member
    im mounting a xj550 in a golf cart, and was wondering if the xj engines have
    any certain angle they have to be at, for oil pick up.
    can i build a pan for a rear sump..?
    any information is greatly appreciated, or if this is just an asinine question. :lol:
  2. TIMEtoRIDE
    100 MPH golfing?? :twisted:
    The sump surface is basically level (stock) and the engine gets oil under HARD acceleration, which would roughly similate a 40* angle (guess) and needs oil under hard braking, too.
    At issue is the carb float bowl, so if you can't mount the engine "level", you may need to get creative with float levels to compensate.
    And in case you don't know, you should plan on using the stock airbox with the inlet restriction, and don't run a wide-open exhaust. You'll need a little fan blowing on the motor. Check your valve clearances, too.
  3. bigfitz52
    You'll just burn it up eventually. A golf cart won't generate sufficient airflow to properly cool that motor.
  4. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    But its a 100MPH golf cart!!!! :)
  5. Beastie
    Beastie New Member
    Ft.Worth Texas
    THIS^^^^ 8O 8)
  6. 0versteer
    aha! thank you, exactly what i was looking for!
  7. 0versteer
    i didn't think of this!
    thanks for the heads up.
  8. 0versteer
    when i get home ill post eye candy for you guys ;)
    we're basically at the mock up stage, trying to find good engine placement.
  9. TIMEtoRIDE
    I agree with Fitz - you can't put an XJ motor under the seat, in a closed box.
    Header wrap will help alot, and so will a MASSIVE oil cooler, like just use a tranny cooler. Too big of a fan will suck the alternator/battery dry. You get 19 amps @ 5,000 RPM and ZERO amps at idle.
