Manual fuel petcock VS vacuum
Discussion in 'XJ Modifications' started by Samson, May 29, 2012.
  1. Samson
    Samson Member
    Lombard, IL
    Hi everyone.
    My fuel petcock started leaking like crazy all of a sudden… looks like it’s leaking out of the turn knob itself.
    I found a gasket rebuilt kit for $20, but for $30 I can get the whole petcock.
    The difference is that the factory petcock is vacuum activated, and the replacement is a manual shot off (on, off, reserve). http://www.ebay.com/itm/NEW-AFTERMARKET ... 0b&vxp=mtr
    I’m trying to decide if I should try rebuilding it (never done it before), or just buy the complete, simplified petcock.
    Any input is appreciated.
  2. zap2504
    zap2504 Member
    Middletown, PA
    I think there are some petcock rebuild threads in XJ Chat. Having a manual version might be better - fewer 20-year old stuff to fail on the road - but the un-named manual version may be of questionable quality. I have a manual petcock in my XT600E and I assume most small displacementdual sport Yamahas do too. Maybe take your old one to a friendly Yamaha parts counter to see if a new OEM manual would have the same bolt spaces?
  3. wwj750
    wwj750 Member
    central minnesota
    I'd suggest doing the rebuild kit. Its really easy & only a few parts. At least you wont have to remember to shut off the valve every time, & risk flooded carbs. You can do it man!
  4. jf2oo6
    jf2oo6 Member
    I recently rebuilt my stock petcock with a kit from chacal. I didnt have such a good experience. The process is simple enough. Clean it really good and make all surfaces as shiney and clean as you can. I followed the instructions to the T, but mine still leaked out of the vent in the plastic spacer.
    Nothing I did would make the petcock stop leaking from that vent. So I took it apart again, removed that plastic spacer and added a gasket over the diaphragm. This effectively makes the factory petcock an "ON OFF" valve. Now my petcock only flows in PRI, the other 2 positions are off. The only problem with this is I lose the reserve funtion. But I just wanted a quick fix for now.
    You can find a manual on off valve on ebay with reserve for like 30$. Which is cheaper than I paid for the kit. That will probably be what I go with next. The vacuum feature is nice if it actually works though.
  5. darkfibre
    darkfibre Member
    Perth, Australia
    I bought the manual kit from chacal, in the last 2 years I haven't forgotten to turn it off.
    Remembering to turn it on, now that is different.
  6. deadohiosky
    deadohiosky Member
    Columbus, OH
    I vote for replacing with a manual petcock, it's just simple and less things to go wrong. I think I paid around $30 for mine and have never had a problem. Of course, growing up riding old dirtbikes, I'm conditioned to always turn it off after a ride.
  7. xjjammer
    xjjammer New Member
    binghamton NY
    i just turn mine on prime
  8. bensalf
    bensalf Well-Known Member
    yorkshire ,england
