Oil leak near oil filter.
Discussion in 'XJ Technical Chat' started by Stone, Jun 12, 2012.
  1. Stone
    Stone Member
    So I just noticed a small leak near wear my oil filter is. I'm wondering if this could be due to tightening it sideways, or if I have a bigger problem
  2. TIMEtoRIDE
    There's a couple of alignment protrusions to help you install it "straight".
    Loosen it with a catch pan, wipe the mating surfaces clean, you may have trapped dirt on the "O" ring, re-install and add a pint.
  3. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    Probably the o-ring on the filter housing. Fram filters come with a new one which I replace each time I change the filter. What did you mean by "tightening it sideways?" If yours is like mine, there's a tab on the filter housing that fits into a slot on the engine--at 12 o'clock.
  4. wwj750
    wwj750 Member
    central minnesota
    Over-tightening can distort the covers O-ring, causing a possible oil leak. My manual says 11.0 ft/lbs-pretty easy to over-do if you dont use a torque wrench.
  5. Durk
    Durk Member
    Pittsburgh, Pa
    I had a problem with a leaky housing, I used some red gasket adhesive on the housing side, then torqued to spec. Let it cure overnight before starting the bike. No leaks.
