got her running great, but there's a whisling noise?
Discussion in 'XJ Technical Chat' started by Gearhead76, Apr 18, 2007.
  1. Gearhead76
    Gearhead76 Member
    Appleton WI
    Finally got her (83 xj750rk) on the road, and she just screams down the street, I like that part, but she also whisles when going down the street, with the clutch out, but it won't make the noise in my garage even on center stand going through the gears, I've heard simalar noises from other bikes but not quite this loud.
    I don't know if this is something to worry about or not, I was thinking clutch discs, but she grabs great, really wants to do a wheelie, I can see why the last guy burnt off the back tire in 8000 miles, she's a fast bike way faster then my 79 cb750f was.
    Thanks in advance
  2. samsr
    samsr Member
    Colorado Springs
    That may be the rear end gears. You may want to check the fluid level in the rear end. Since it only seems to make the noise while under a load. Easy check. Just pull the plug on the side of the diff and take a look. If fluid is at the top, your good. If low, Go ahead and change it. I would probably change it anyway. If you havent all ready. Just use some 80/90w hypoid gear oil. cheap insurance
  3. Gearhead76
    Gearhead76 Member
    Appleton WI
    Here I was thinking the worst something in the tranny, and over looked the easy, I'll check that tommorow.
    Wow 12 years of working on cars has made me brain dead.
  4. RickCoMatic
    Your former Chain-Drive Life moves into Shaft Drive, now ... right?
    My son, you just might be hearing the infamous "Middle Gear Whine" ... for which our beloved XJ-Models are well known for ... world wide!
    Yeene-yeene-yeene, neee-nee, yeeeeeeeeee!
    That sweet Middle Gear singing the only one tune it knows ...
    Nice.
    Shaft drive rules.
  5. mr_ex
    mr_ex Member
    maine usa
    that middle gear sing is what made me fall in love with these bike many many moons ago :p
  6. Gearhead76
    Gearhead76 Member
    Appleton WI
    That could be it, sounds like a belt drive bike almost, that kind of weerlie or whisle noise, I have a 77 goldwing with shaft drive and have also had a 82 silver wing with shaft drive and they were a lot quieter.
    But if it's a normal noise then I'll just ride it,
    Oh ya the gear lube was full, but I changed it anyway
  7. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    My Maxim makes the same noise, and it drove me absolutely crazy until I found out what it was! Now I just imagine its a jet engine winding up 8)
  8. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I noticed when I hear that screaming noise, I look up and it's a Yamaha. Mine used to drive me crazy, but I must be used to it now. It seems alot of 4 bangers have a certain noise about them. It seems to come from the top end and the Yamahas are the loudest I've noticed.
  9. Russxlr8s
    Russxlr8s Member
    Phoenix, Az
    I always loved that whine (charger) kind of sound from the maxim 650, it was a more predominate sound on the 650 then the bigger bores and my 1100 doesn't do it at all. I wish it did as I love that sound.
  10. eatatjoz
    eatatjoz Member
    Mayflower, Ar
    I miss that whine.
    After I changed the stock 18 to a Virago 16 rim, it was even more noticable. Hell, I'd keep it at six or eight grand just to hear her sing.
  11. Robert
    I love the sound of a hypoid gear, catches my ear every time.
  12. Alive
    Alive Active Member
    Queensland, Australia
    I was wondering what that was :lol:
    Funny thing is though... I really can't hear it when I'm giving it a fist full... Might be because I'm too busy holding on :p
    I'm seriously loving the power and comfprt of my stunning ride... Fills me with joy :D
  13. mr_ex
    mr_ex Member
    maine usa
    my seca had a cam noise at about 4k that was awesome....sorta like the cams were playin the drums.......i miss that bike......for an 82 that thing would haul azz.
