Insurance question
Discussion in 'XJ Technical Chat' started by Rastacia, Jun 22, 2012.
  1. Rastacia
    Rastacia Member
    something I have never had to worry about but I have just tried to insure my bike and they are asking me if I have a standard xj750 or a seca . For some reason a Seca is more to insure than a standard XJ750. I must admit I thought they were either Secas or Maxims .
    My frame and engine number indicate its a XJ750 A model , so what oes that bring me to ??????
  2. MiGhost
    MiGhost Well-Known Member
    The Seca is considered a sport bike. While the Maxim is considered a cruiser, or standard bike.
    The sport bikes are generally thought of as more for the go fast type rider which in turn unfortunately leads to more damage/injury in the case of an accident. Due to this the insurance companies charge higher premiums for the sport bikes.
    This will tell you all you need to know to determine whether you have a Seca, or Maxim.
    TECH TOPIC: Model ID and VIN's
    Ghost
  3. Bushy
    Bushy Active Member
  4. Rastacia
    Rastacia Member
    well heres a pic of what it was , does look like the 650 seca frame but definately doesent look like a sports bike
    I think I may list it as what the insurance called a "standard" xj750 before I start listing the mods
  5. Bushy
    Bushy Active Member
    Looks just like mine basically, what's th engine # ?
  6. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Just an excuse by the insurance company to charge more. The Seca may look more sporty but when it boils down to it I don't think they were any faster than a Maxim. Now handling may be different with the anti dive forks and such, would make the bike corner and handle better.
    I would shop more insurance companies and see if you can find the best deal possible.
  7. Rastacia
    Rastacia Member
    its a 750 buddy
  8. Bushy
    Bushy Active Member
    Yeah i get that it's a 750 .. i was just curious what th engine / frame numbers are considering your initial post.
    Buddy
  9. Rastacia
    Rastacia Member
    sorry its 5G8 which points to japanese A model
  10. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Where are you at if your in the U.S Country Financial has SUPER cheap bike insurance my maxim x is like $17 a month for liability and I have a bike wreck on file...
  11. hogfiddles
    That is an XJ750 Seca. Ahem.......read between the lines----Looks like its a "Maxim that has LATER been modified to LOOK like a Seca"------. hint hint hint HINT...
    If anyone asks to see a pic, drop a 750 maxim tank on, carefully borrow a couple side covers and a seat, stand back and take the pic.
    This s not a 750R type of seca....the race-y ones. This is a plain-jane seca, that is almost no different than the maxim other than some cosmetic differences and minor other stuff
    D
  12. Rastacia
    Rastacia Member
    well it doesent look like either at the mo But I will add pictures tomorow when its finished , hence insuring it quickly so I can take it for its MOT ( ministry of transport roadworthy test)
  13. ManBot13
    ManBot13 Well-Known Member
    Fairfax, VA
    It definitely looks like a seca.
    I'd always advise against lying to an insurance company. You'll get away with it just until you get into an accident, then they'll be able to wash their hands of you because YOU lied. Doesn't make a difference if it's a little white lie, unfair, etc. Insurance companies may be the scum of the earth, but they'll make you pay if they can and when it hurts the most.
  14. smurf667
    smurf667 Member
    Newark, Nottinghamshire, England
    Rastacia, it sounds like you are in the UK, are you? If so, where?
    Pete
  15. MiGhost
    Now to make it even more confusing!!
    Taken from above posted link
    COUNTRY: JAPAN
    MODEL NAME: XJ750A
    STREET NAME: 1981 XJ750
    MODEL ID CODE: 5G8
    FRAME ID: 5G8
    SERIAL NUMBER STARTS AT: 000101
    NOTE: uses the XJ650RJ Seca frame, but has the 750 engine.
    MODEL NAME: XJ750D
    STREET NAME: 1983 XJ750
    MODEL ID CODE: 5G8
    FRAME ID: 5G8
    SERIAL NUMBER STARTS AT: 020101
    NOTE: this model features fuel injection.
    NOTE: Although the North American market was treated to three different versions of the XJ750 model (Maxim/Midnight Maxim, Seca, and the previously mentioned XJ750 Maxim-X versions), the rest of the world generally had only one version available, and that version is most similar to what is known as the XJ750 Seca model in North America.
    Although not generally referred to in the overseas markets as a "Seca" model (since there was only one model available, there was no need to give it a "name" needed to differentiate it between a base Maxim model), these overseas versions came equipped with the "scalloped" design fuel tank, gauge package, and other special components which are normally found in the North American XJ750 Seca models.
    The pic of the bike clearly shows what is considered to be a 750 Seca in the US. As evidence by the remote front brake M/C, anti-dive forks, Side covers, and tail cowl. BUT! It also clearly shows that the bike is carbureted, and not the fuel injected XJ750D. This may be a modification!
    But then again! It does not appear to be the XJ750A. Which would be a factory design of mating the 750 engine into what is considered in the US as the '82 XJ650R Seca chassis. The bike in the pic does not fit that description either.
    Either way. It is an import to all markets other than Japan/Oceana (incl OZ, NZ), and would be considered a standard model in every market except North America.
    It would have to be a 5G2 to be clasified as a US Identified 750 Seca.
    Any insurance company should have the abiltiy to properly ID the bike from the VIN.
    Ghost
  16. Rastacia
    Rastacia Member
    cheers Ghost . I think I will just go to a Motorcycle specific insurer and do it from the frame number , that way there cant be any confusion , next thing is I wonder how much they will charge me for the bodywork modifications. It hasnt been changed power or brake wise yet but I guess its more Stealable
  17. MiGhost
    What bodywork modifications?? I didn't see any in that pic! :lol: :lol:
    Ghost
  18. Rastacia
    Rastacia Member
    patience my friend :)
