K&N air filter (stock replacement) Worth the money?
Discussion in 'XJ Technical Chat' started by superluckycat, Jun 24, 2012.
  1. superluckycat
    superluckycat Member
    United States of Insanity
    Waddya think? If not, who has inexpensive filters?
  2. bigfitz52
  3. Ross1
    Ross1 Member
    Syracuse,NY
  4. superluckycat
    Re: K&N fir filter Worth the money?
    I've heard that.
    I just got the carbs back on the bike today after replacing the throttle shaft seals, all the o-rings, gaskets and drain screws (two were stripped).
    I'm sick of carbs for a while.
  5. need2speed3
    need2speed3 Member
    They have great GGL factor (gonna get laid) ;-)
  6. biggs500
    biggs500 Active Member
    Sherwood WI
    I would agree to stay with the stock filter. I am running a K&N and went up one size on the main jet (110 to 112) and stock pilot jets, I don't remember off hand what size those are. I think I'm a tad lean on the pilots as I do get just a small amount of popping from the exhaust under heavy compression braking. The only advantage I see is the K&N is reusable. Honestly I didn't see any performance increase.
    If you want to re-jet then try the K&N but it's a slippery slope when trying to re-tune these things.
  7. ryancdossey
    ryancdossey Member
    Indianapolis, IN
    Or you can go with the "uni" that Chacal offers. It is cheaper than the oem. reusable, and Generally does NOT require any rejetting.
  8. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    Think people are confusing pods and kn oil coated stock style airbox filters in this post...
  9. smurf667
    smurf667 Member
    Newark, Nottinghamshire, England
    I too have the K and N oil coated stock style airbox filter, it was already fitted when I got the bike in 2009. If you're on about that one and not the pods, then you should be ok.
  10. DuoDS
    DuoDS Member
    South Jordan, UT
    Running a K&N oiled, stock style filter on my Seca as well. Runs strong and I did not re-jet.
    Now if I can just stop the oil leak.
  11. Shleprock
    Shleprock New Member
    Austin TX
    Running a K&N oiled, stock style filter on my Xj650J, no adjustments and no problems.
  12. 44Dave
    44Dave Member
    Nebraska
    Replaced my OEM style with K&N oiled stock style and no adjustments needed... yet.
  13. superluckycat
    I was talking about stock replacement, not pods. I'm not ready for that adventure......yet.
  14. maximike
    maximike Member
    Portland, OR, USA
    I think Fitz was referring to stock airbox with a K&N filter. Believe it or not, that link to Chacal's info *does* indicate carb changes even with the stock airbox and a K&N stock replacement filter.
    I'm running that exact set-up (bike came that way) I cleaned and re-oiled it when I got it, haven't had to re-jet. I really really doubt the P.O. did either, but I guess it's possible. Anyway, I'll chime in on the "no problems" band wagon, as far as K&N stock airbox set up.
    P.S. I read that site above about high-flow filters letting in more dirt, that Ross1 posted. If anything it seemed to say that K&N was the best of the high-performance filters, but yes, totally stock is the cleanest.
