'Wet' Cylinder - Exhaust Side
Discussion in 'XJ Technical Chat' started by robvoi, Jun 25, 2012.
  1. robvoi
    robvoi Member
    Hi guys,
    '81 XJ550 Seca, in the process of replacing the header gaskets and noticed that cylinder 1 (counting from left to right) is 'wet'; the other 3 are dry.
    I had a buddy ride behind me for about 1 hr, no oil smoke or anything.
    The bike sits upright in a chock.
    What am I missing? Life treatening?
    Thank you for the feedback.
    Robert
    :oops:
  2. mlew
    Is it wet with oil or gas?
    Wet with gas is a carb or ignition problem.
    Wet with oil is problems in the rings or valve guide seal.
  3. robvoi
    robvoi Member
    Let me do a smell test
  4. MiGhost
    MiGhost Well-Known Member
    Along with doing a smell test. Pull the plug on that cylinder, and check to see if it is also wet.
    Ghost
