Just bought a 82' 650 maxim
Discussion in 'Hangout Lounge' started by redlightningsvx, Jun 28, 2012.
  1. redlightningsvx
    redlightningsvx New Member
    Just bought a 82' 650 maxim off craigslist for $200. The good it runs good, no frame damage, and a title. The bad it needs a gas tank which I read a 750 tank will work, a seat since it doesn't have one, has 40k, and needs a paint job. Questions Wanted to know what I should do while its apart? I do plan on getting an engine reseal kit since it leaks oil in the exhaust. Any advise is appreciated.
  2. Heysus
    Heysus New Member
    woah!
    THAT'S a deal!
    Sorry I wish I could be of assistance but I'm in the process of acquiring my first one soon. Just browsing to see what other prices other people have paid.
  3. CadMonster650
    CadMonster650 New Member
    Carver, Minnesota
    http://xjbikes.com/Forums/viewtopic/t=14692.html
    Check out the carb cleaning link above. among other things you should really pull the carbs and clean/inspect them. after that, brakes (especially rear), fork seals, and valve clearances. mine looked just like that when i picked it up, but little by little they do clean up pretty nice!
  4. Kwiski
    Kwiski Member
    High Desert CA.
    Nice grab! That is what I paid for mine. Did all services. She ran like a champ.
  5. redlightningsvx
    Do plan on rebuilding/cleaning the carbs. It does need fork seals and rear brake I found out when I took it around the block. Luckily the front worked, as far as paint I like the black/gold of the midnight maxim so was leaning toward something similar but with a gold painted motor w/ black accents. Here's some pics of it currently.
  6. redlightningsvx
    Painted the frame
  7. redlightningsvx
    Got a few things done so far. Been debating on engine colors lately. Wanted to go either a gold motor with black trim or flat black with gold trim? What do you think
  8. maverickbr77
    maverickbr77 Member
    Lowville, New York
    black with gold trim is probably safer the gold with black trim might be a bit overpowering, but it might not look bad either. Best thing to do is try and play with colors in some image editing software.
  9. Buffalony
    Buffalony Member
    Corning NY
    Check with chacal. He might have gold carb hats and gold tank trim. Maybe some other goodies to help you get the look you want.
    Good Luck
