idle speed high
Discussion in 'XJ Technical Chat' started by j13jcg, Jul 7, 2012.
  1. j13jcg
    j13jcg Member
    hi all . my xj700 is adling at 3500 rmp and will not go down if adjusting the idle screw , any ideas thanks john
  2. bigfitz52
    Sure--
    Time for carb cleaning and service, valve clearance check and carb sync.
    Check for obvious vacuum leaks (petcock vac line, vacuum spigot caps, etc.)
    Any mods?
  3. j13jcg
    j13jcg Member
    i have checked the valve clearence and replaced any that was out . cleaned the carbs and set the floats with a clear tube , was syncing the carbs all morning but cant get the rev down
  4. bigfitz52
    Depending on the accuracy of your initial bench sync, either you're still way out of sync;
    or you have a vacuum leak somewhere.
    I'll ask again: Intake or exhaust mods?
  5. j13jcg
    j13jcg Member
    no leaks so must be carb sync . here we go again
  6. bigfitz52
  7. adrian1
    adrian1 Active Member
    Hang up somewhere on throttle cable?
  8. j13jcg
    j13jcg Member
    hi . only mods a k/n filter everything else standard
  9. j13jcg
    j13jcg Member
    cant get 1 and 2 to level out . wen i turn the screw one way they get further appart an the carbtune bet the rev goes down . turn it the other way and the rev goes higher and higher . starting to think its time to sell
  10. j13jcg
    j13jcg Member
    help help help please
  11. trickedout420
    trickedout420 Member
    Greenwood MO
    are your band clamps holding any of the blades open i had this problem...is the adjuster on your throttle cable right PO had mine all the way turned in and when i cleaned the carbs and started it up it rev'd up to 9 grand and stayed there all i did was adjust it down until the idle screw picked it up
