82 xj750j cam interchange
Discussion in 'XJ Modifications' started by hash, Jul 6, 2012.
  1. hash
    hash Member
    quebec
    what other cams will fit a xj750j and give a good hp boost?
  2. Ledicott96
    Ledicott96 Member
    North west England
    No idea if you can swap them with another bike but I believe Yoshimura made race cams for the Xjs back in the day but good luck finding a set now.
    Al
  3. TIMEtoRIDE
    Send them off for a re-grind, supply your own #'s, supposed to cost $400
    You'd be building a custom "race" motor and would match or improve the intake, exhaust, and compression, and be experimenting beyond the usual advise of this site.
    Search - worldsfastestxj550 for ideas.
  4. Ledicott96
    Ledicott96 Member
    North west England
  5. kevineleven
    kevineleven Member
    Columbus, Ohio
    I have a cb750 and I dropped in cams from a cb900, with noticeable HP gains, and zero modifications. They've been doing this swap for years on the DOHC Hondas, I'd be interested to see if the 750-900 swap would work on an XJ.
  6. MiGhost
    MiGhost Well-Known Member
    No this will not work. The 900 came out with a 4 point cam support in the head. The 900 cams will not fit into the 750 heads.
    900 Head showing 4 point cam support
    750 Head showing 2 point cam support
    images taken from 900, and 750 service manuals
    Ghost
