no spark
Discussion in 'XJ Technical Chat' started by Darth_Menace, Jul 10, 2012.
  1. Darth_Menace
    Darth_Menace Member
    Alberta
    Hey guys..I've been having a problem getting my bike started. Anyways, we figured out that there is no spark. Do you have any idea of where we'd look
  2. mlew
    Could be several things, go through this list.
    1 ) Battery, is it fully charged? What is the voltage when starting?
    2 ) Fuses, are they good? If you have the OEM fuse box consider replacing it. Make sure all connections are clean.
    3 ) Side stand saftey circuit. Is the relay grounding the TCI?
    4 ) What is the voltage at the TCI when starting? If it is below 10.5V it will not work. Check and clean connections from the battery to the ignition switch.
    Thats a good start, there could also be a problem in the TCI. We'll go there next.
  3. Darth_Menace
    Darth_Menace Member
    Alberta
    Thanks for your info. To answer the questions in order.
    1). No, the battery is week, but I had cables connected to a car when I was trying to start it.
    2). Fuse box is crapped. Connections are wobbly, but still make a connection so this is why I didn't think it would be that.
    3 and 4). I have no clue
  4. Darth_Menace
    Darth_Menace Member
    Alberta
    I should add that I can press the start button and it sounds like it is making great attempts at starting as per usual, but no go. First we thought it was gummed up carbs, but then the spark plugs were tested and we saw no spark :(
  5. manuellabor
    manuellabor New Member
    canada
    I had the same issue with no spark on the xj 1100 and it turned out to be one of the safety switches
    Manual states for when engine will not start:
    check ignition circuit for connections
    check battery voltage
    check fuse and fuse connections
    check ignition coils
    check pick up coils
    check operation of emergency shut off switch
    check operation of sidestand switch and relay
    If that is all good
    replace tci
    this is from xj 1100 manual, but i am sure same procedures will help find the problem
    Hope this helps
    I would personally check your ignition fuse first
  6. Darth_Menace
    Darth_Menace Member
    Alberta
    One of the ignition coils is pooched. This is stupid. I can't even find the part number of the fische. Why would one crap out ll of a sudden
