fuse box options?
Discussion in 'XJ Technical Chat' started by ifonly2005, Jul 13, 2012.
  1. ifonly2005
    ifonly2005 Member
    exeter nh
    1980 yamaha maxim 650
    i redid my fusebox a while back, and it works fine, but is a pita where i put it..... im going to redo it right this time.... and wanted to go with something like
    http://www.ebay.com/itm/6-Way-Blade-Fus ... 2a199601a4
    my question is do you think this is a bad idea? my worries are that the battery putting out a straight power to all sources will be too much for the battery..... and if not that, does any of the bikes electrical lower or raise power??? meaning will anything malfunction if i do this setup? please and my bike thanks you!!!!
  2. Paiva
    Paiva Member
    Tewksbury, Ma
    I beleave this is a distribution block not a fuse box.
    In google type it "xjbikes Mini blade fuse block"
    Check that thread out
  3. mlew
    That one won't work, it is meant for power distribution and not for individual fused circuits. PM Chacal, he has a fuse box kit that will fit your bike. You can get similar ones at a autoparts store but they won't have wire, terminals and mounting hardware with it.
  4. ifonly2005
    ifonly2005 Member
    exeter nh
    you have 1 wire coming in from battery, and 6 wires going out for positive to each "line" i have one in my jeep for all my horns lights and ect ect... works great.... just wasnt sure if anything on the bike uses the voltage regulator or anything
  5. ifonly2005
    ifonly2005 Member
    exeter nh
    i read the other post.... i get it now. thanks guys.... this is why i asked first.... i would have been peeved if i got another one and hooked it up to watch nothing!!! do you know if chac's fuse boxes are for atms or the glass ones?
  6. maverickbr77
    maverickbr77 Member
    Lowville, New York
    The one we generally recommend from chacal is a atm style fuse box
  7. Paiva
    Paiva Member
    Tewksbury, Ma
    This is what I used. I have a few more if you want them. They link together for a neater look.
  8. Paiva
    Paiva Member
    Tewksbury, Ma
    see
  9. JPaganel
    JPaganel Well-Known Member
    Minneapolis
  10. ifonly2005
    ifonly2005 Member
    exeter nh
    i appreciate all the tips. i just went to my garage and found an old fuse box i pulled out of a ranger i scrapped. ive relined a few wires, and will cut it tomorrow. will post pictures of my progress. free is cheap enough for me. i have ammo boxes on the bike... so i think itll go in with all my other wires.
  11. bigfitz52
    I rebuilt my original with new clips from Radio Shack. Total cost under $4. But it does mean continuing to use the glass fuses.
