Hitachi Carburetor Jet sizes
Discussion in 'XJ Modifications' started by jamcam1999, Jan 25, 2011.
  1. jamcam1999
    jamcam1999 Member
    <a href="http://maps.google.com/maps?q=50.064192+-
    Does anyone have a chart (accurate measurements) of the hole sizes in the Hitachi carburetor fuel jets? Would be nilce to know. Thanks in advance for your input. Jack
  2. cutlass79500
    lawrenceville georgia
    I am sure someone does have 1 hopefully you will get an answer shortly
  3. mlew
  4. RickCoMatic
  5. Rastacia
    Rastacia Member
    can you confirm though that a 120 Hitachi jet is 1.2 mm as I am not so sure it is !!!. I dont have any other jets to try but I have just checked a 43 pilot jet it it comes out at .39 mm
  6. kevineleven
    kevineleven Member
    Columbus, Ohio
    Not all manufacturers use this chart for sizes. Check that you have Hitachi jets in the Hitachi carbs. I know a Dynojet #130 is not the same as a Keihin #130 etc...
  7. RickCoMatic
    It's not at all uncommon to find the wrong Jets installed in used Carbs.
    People swap Jets to fix Float Pillar damage and often overlook the AIR Jets.
    And, its quite common to find the AIR Jets reversed after a major cleaning, due to a misprint in the Haynes Manual.
