Bike died on a bumpy stretch - won't start now
Discussion in 'XJ Technical Chat' started by eman1974, Jul 17, 2012.
  1. eman1974
    eman1974 Member
    Halifax, NS, Canada
    Hit a really bumpy sectionof road as I approached a stop sign. Bike shut off and now it won't start. Obvisouly something shook/broke loose.
    When I push the start button I hear a clicking at the battery, but it does not turn over.
    Any ideas at where to start? I don't see anything obviously disconnected.
  2. phoenixlives
    phoenixlives New Member
    Newport News, VA
    I've had this happen. Pop your seat and make sure the fuses are seated properly.
  3. eman1974
    eman1974 Member
    Halifax, NS, Canada
    tried that. no luck. thanks though. :)
  4. mlew
    Starter solenoid and/or starter. Check the cable connections first to see if they are tight.
    jump the solenoid terminals with a pair of pliers and see if the starter turns. If it does then you have a bad solenoid if not then you have a bad starter. Of course make sure the battery is charged first. I would also check the fuses to make sure nothing else came loose.
  5. eman1974
    eman1974 Member
    Halifax, NS, Canada
    OK, complete Newb/dunce here. How does one "jump the solenoid terminals with a pair of pliers."
    Battery is fine. Fuses are good and tight.
  6. eman1974
    eman1974 Member
    Halifax, NS, Canada
    OK, I think I know what you mean. Tried that. No results.
  7. eman1974
    eman1974 Member
    Halifax, NS, Canada
    The solenoid is working. I can hear the slicking coming from it.
    Would the starter be the problem since the bike was running when I hit the bumps and it just shut off?
  8. Wrench26
    Wrench26 Member
    Fort belvoir, VA
    no sounds like you may have broken a ground wire back to battery. check all ground wires
  9. eman1974
    eman1974 Member
    Halifax, NS, Canada
    Seems like I had a compound problem - bike shutting off on the bumps (unknown). Restarting the bike = a starter problem - thanks to a friend with some old school mechanic skills. Tap the starter with a hammer and tada!
  10. schmuckaholic
    California
    Iffy connection inside the TCI, perhaps? Might not hurt to open the puppy up and check the solder joints.
    Cool. Now you're an expert at diagnosing the starter. :D
  11. mlew
    Figures it was the starter but you still have the shutting off problem. I would not ignore that one it could leave you stranded sometime. Put the bike on the center stand and start it. Go through the all the wiring connections and wiggle them to see if you can find that loose connection. It could be anywhere.
